FTMC Jarvis 16.2.31
I have been using FTMC without crashes using Confluence Zeitgeist skin (since my last message here complaining about problems). I absolutely recommend that skin, it's an updated and improved version of Confluence that is even smoother than Confluence, and includes krypton icons and nice graphics. Freaking amazing, test it out. Now that FTMC does not crash I can see its perfomance. Amazing job SC, absolutely amazing. Actually it's working better than SPMC, which I have in another box.Last edited by kerenmac; 28 February 2017, 09:56.
Originally posted by kerenmac View PostI have been using FTMC without crashes using Confluence Zeitgeist skin (since my last message here complaining about problems). I absolutely recommend that skin, it's an updated and improved version of Confluence that is even smoother than Confluence, and includes krypton icons and nice graphics. Freaking amazing, test it out. Now that FTMC does not crash I can see its perfomance. Amazing job SC, absolutely amazing. Actually it's working better than SPMC, which I have in another box.
Originally posted by Foolproof View Post
Yoka kb2 s912 has Kodi 17.0 installed default I mean, you try hard downgrade.....
It is not rather a software downgrade, I think ?? no a hardware downgrade !
I already updated my original firmware with the same in date of : 2016.11.23 from here :
https://androidtvbox.eu/new-firmware...161123-release
I already installed spmc from google-play; kodi 17 on this rom is a beta version not installed with google-play, therefore, I uninstalled it manually to replace it by the final version of kodi 17 (fev 2017) with google play.
On the other hand, I note that for the reading of the same film in h265 with SPMC the soc temperature oscillate between (45° - 50° C); while with kodi for the same film in h265 the soc temperature goes up to oscillate between (58° 65° C) !!! strange ....
Therefore I get information about FTMC and Superceleron rom of which I read much praise, and not only on this forum; it's for this reason, I ask all these questions.
hmm need to try that skin, is in a repo anywhere? or is in the "normal" kodi repo?
Originally posted by jeanluc56 View Post
Hello,
Spmc/Ftmc it uses the amlcodec so the cpu usage it way more low and that means less heat of course and smoother playback.
Originally posted by uli-hh View Post
Originally posted by superceleron View PostBuild 24 up on the 1º post
Just need to verify so I no witch no limits build to add-on
and while i'm at it what is the difference between the standard SPMC.apk's and the Launcher_SPMC.apk's
"I'm Waiting ever so patiently for your ATV rom For BB2-Pro"
Thanks in advance,
phatboyj
Originally posted by phatboyj420 View Post
Just to be certain these are Jarvis based Correct?
Thanks in advance,
phatboyj
The SPMC differences are explained here
http://forum.kodi.tv/showthread.php?tid=212601R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thanks in advance,
phatboyj
There are currently 3426 users online. 1 members and 3425 guests.
