FTMC Jarvis 16.2.31
Originally posted by EagleEyeXZ View PostHi superceleron maybe this is allready asked but i coudn't find it. Will FTMC move to kodi 17 based? Or just like koying said when kodi 17 is ready for daily use?
If you don't use pass-through or auto frame-rate switching then Kodi 17 should work well.
Devices with Nougat firmware will be able to use Kodi 17 with all features working.
Rockchip launched Nougat and I see Amlogic is also testing it.
Lollipop has zero native pass-through support, Marshmallow only has native DTS/AC3 no HD Audio support.
Nougat is the first Android OS that has native HD Audio pass-through support without any manufacturer hacks.
Without Nougat firmware don't expect things like pass-through to work 100% on Kodi 17.
Kodi 17 + Amlogic/Rockchip Marshmallow firmwares don't work well together.
I don't think it's possible until Koying and all the other Android Kodi's all move to a Kodi 17 base as Kodi 17 still has lots of bugs and no Android maintainer.
Originally posted by scooter2014 View PostThis is the offical FTMC Thread special thanks SuperCeleron for working so Hard on this for all the Freak Tab Members.
Below are all the Builds and change logs SuperCeleron changes to FTMC. As always latest will be at the top of this post
FTMC General/AML Build 24 -> General/AML Build 24
Originally posted by graphdarnell View Post
I flash SC-RC3 on an MK8 Pro box, which has FTMC pre-installed. Upgraded to Build 24. Noticed a bug. About 20 minutes into any streaming, the app would either freeze (similar to Amlogic S802 and Kitkat with Kodi), or crash and revert back to the previous listing page. Prior to this, I've used SPMC and didn't notice anything unusual. Has anyone experienced this and succeeded in fixing it? Any input would be appreciated.
What are you streaming from and are you using any specific addon?
I'll get a log and post it here. Attached is a snapshot of the temp folder. I take it that you would want the kodi log at the bottom, SC?
Thanks for responding.Last edited by graphdarnell; 16 March 2017, 20:33.
Content of Kodi log:
[QUOTE
11:52:39.245 T:18446744073501665584 INFO: void XCURL:llLibCurlGlobal::CheckIdle() - Closing session to http://www.freaktab.com (easy=0xd91e8000, multi=0xd93ae9f0)
11:52:39.634 T:18446744073501665584 DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
11:52:39.635 T:18446744073501665584 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:52:39.635 T:18446744073501665584 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:58:03.166 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkcodec.mpeg2"
11:58:03.166 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkcodec.vp9"
11:58:03.166 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkmc.frachdmi"
11:58:09.788 T:18446744073501665584 NOTICE: Storing total System Uptime
11:58:09.788 T:18446744073501665584 NOTICE: Saving settings
11:58:09.792 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkcodec.mpeg2"
11:58:09.793 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkcodec.vp9"
11:58:09.793 T:18446744073501665584 WARNING: CSettingsManager: unable to save setting "videoplayer.rkmc.frachdmi"
11:58:09.803 T:18446744073501665584 NOTICE: stop all
11:58:09.809 T:18446744073501665584 NOTICE: stop player
11:58:09.843 T:18446744073501665584 NOTICE: ES: Stopping event server
11:58:09.843 T:18446744073501665584 NOTICE: stopping zeroconf publishing
11:58:10.749 T:18446744073063897392 NOTICE: ES: UDP Event server stopped
11:58:10.754 T:18446744073501665584 NOTICE: stop sap announcement listener
11:58:10.755 T:18446744073501665584 NOTICE: clean cached files!
11:58:10.756 T:18446744073501665584 NOTICE: unload skin
11:58:10.854 T:18446744073089845552 NOTICE: Icelibrary2 Service stopping...
11:58:11.264 T:18446744073087756592 NOTICE: Stream All The Sources: Service: shutting down...
11:58:11.265 T:18446744073086712112 NOTICE: INDIGO NOTICE: CLOSING INDIGO SERVICES
11:58:11.284 T:18446744073085667632 NOTICE: DudeHere Common Routines: Service stopping...
11:58:16.291 T:18446744073501665584 ERROR: CPythonInvoker(6, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.dudehere.routines/service.py): script didn't stop in 5 seconds - let's kill it
11:58:16.381 T:18446744073083578672 NOTICE: 1Channel: Service: shutting down...
11:58:19.162 T:18446744073501665584 NOTICE: stopped
11:58:19.162 T:18446744073501665584 NOTICE: destroy
11:58:19.183 T:18446744073501665584 NOTICE: closing down remote control service
11:58:19.184 T:18446744073501665584 NOTICE: unload sections
11:58:19.198 T:18446744073501665584 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:58:19.402 T:18446744073501665584 NOTICE: destroy
11:58:19.403 T:18446744073501665584 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:58:19.404 T:18446744073501665584 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:58:19.405 T:18446744073501665584 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:58:19.405 T:18446744073501665584 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:58:19.405 T:18446744073501665584 NOTICE: closing down remote control service
11:58:19.405 T:18446744073501665584 NOTICE: unload sections
11:58:19.405 T:18446744073501665584 NOTICE: application stopped...
[/QUOTE]Last edited by graphdarnell; 19 March 2017, 19:22.
Originally posted by graphdarnell View PostContent of Kodi log:
Also maybe you are using Rockchip settings that are enabled while you shouldn't because you are using an Amlogic S912 with broken passthrough.
Try to install a custom S912 firmware and you should have much better results and keep the installed addons to the minimum.
You probably have too many broken addons installed.
Another twist: I tried adding SPMC 64, but it won't install. Earlier, I had SPMC on, and tried Kodi, then TFMC separately. Neither would stick. In other words, this firmware on my box only takes 1 among 3 at a time. Somewhere in this thread, SC mentioned it would take FTMC with one other.Last edited by graphdarnell; 17 March 2017, 20:34.
Thanks for the guidance. The addon part, I can understand. The firmware, however, I'm not sure what you referred to. Are you talking the RC3 or the FTMC? If just the FTMC, can't I just turn off the RK settings?
But you can have SPMC with another Kodi installed.
Recommended to only have 1 Kodi installed as it can slow your device down and interfere with each other.
In FTMC, disable all the settings under the RKMC menu.
For firmware it is not the Kodi, it is the whole operating system, Android Marshmallow I talk about.
It has lots of bugs on your device and you need to try to update it with a custom firmware that fixes some of the bugs and brings new improvements if there is one available for your device on freaktab, I'm not sure.
Your device is only 32-bit.
Don't believe all the shiny advertisements when being the device, they are all lies.
The CPU is 64-bit capable but the firmware is all 32-bit, so everything still runs at only 32-bit.
You can try the normal non 64-bit SPMC and it should work better.
You can't have Kodi, RKMC or FTMC installed at the same time.
I would like to start with great work! I have been testing ftmc with amlogic s905x and it works great. I have noticed that when searching for a video with ftmc, I sometimes miss some HD sources as compared to libreelec. I have tested spmc and I get the same result. I use the same exact addon and addon settings for all 3 setups. Can anyone explain to my why that is? It greatly reduces the amount of 1080 links and often there are none at all.
Originally posted by vadergr View PostAnyone knows if it works with Yundoo Y8?
Especially for dts passthrough.
Maybe DTS will work with Kodi 17.1 but not HD Audio then it will use the Marshmallow firmware's built-in DTS support instead of IEC61937 that is used in FTMC, RKMC, SPMC.
There are currently 2385 users online. 1 members and 2384 guests.
