In my opinion it's not a good idea to change the path for FTMC. The good thing about sharing the path of Kodi is that custom libraries work also on FTMC. Having a different path is the reason for custom libraries not working on SPMC, because they were built for Kodi. I suppose that upgrading from build 25 to 26 would also take more time, because the data and all the paths from Addon settings would have to be changed.
FTMC Jarvis 16.2.31
superceleron Build 25 works perfectly, thank you so much. No problems a all with addons, all SSL problems solved and everything super-smooth. I'm now trying to solve some errors of the Confluence-Zeitgeist skin, but I haven't got much free time.
Originally posted by Gellimo View PostIs there an ftmc version for Android 4.2.2?
Originally posted by kerenmac View Postsuperceleron Build 25 works perfectly, thank you so much. No problems a all with addons, all SSL problems solved and everything super-smooth. I'm now trying to solve some errors of the Confluence-Zeitgeist skin, but I haven't got much free time.
Also addons that use direct path instead of special path, means the coder took the easy way of doing it...
But we shall see when i rls it
Originally posted by superceleron View PostFrom build 26 -> up, FTMC its going to have its own name and path so it can be used at the same time with Kodi
I was also curious: any plans go have it added to Play Store or Aptoide so that people can stay up to date a bit easier?
Thanks either way! FTMC has been a life saver for all the boxes I've helped my friends with and I always highly recommend it.
Originally posted by lyricidal View Post
That's awesome superceleron!
Hi thanks for best work .
I have a question .
I want to use FTMC Rockchip Build 25 to my ZIDOO X6 Pro / Android 5.1 & RK3368 and i have a stupid question .
I use a "Kodi build" , i have 2 options to install : 1.Build for kodi 16.1 / 2.Build for kodi 17.1 .
What version are correct for using with FTMC Rockchip Build 25 ?
Thanks a lot
superceleron
Hi, I see in FTMC there are no options for DTSHD or TrueHD in the sound options for FTMC v25 RK after enabling Expert mode.
Do you know how to add it?
Maybe this patch is missing? - https://github.com/JamesLinEngineer/...1c883a2be685e8Last edited by mo123; 15 April 2017, 13:20.
It will be fixed in build 26
Thks!
There are currently 2483 users online. 0 members and 2483 guests.
