FTMC Jarvis 16.2.31
Originally posted by BTR11 View Post
From Rockchip oficially rk3188 never progressed beyond jelly beam, I guess; KK was a matter of independent devs, and now LL; but RKMC supports KK 4.4 on rk3288, for that it´s the question; so if it´s not a technical hardware limit reached may be a developer can incorporate rk3188 on the list of working SoC with rkcodec; may be just dreaming to continue squeezing some more juice from this device.
So even if a dream, that is where it will stay I'm afraid.
Originally posted by mikele View PostAMLogic codec are used transparently ? Can we know when AMLogic codecs are used ? whats difference with other codecs ?
4th line down is the Video Player. You should see in the line something like am-h264 which is the AM codec. amc or amc(s) refers to Mediacodec. If you see ff or something else, then it is probably using software decoding.
well if its doing the same with kodi 16.1 then your tablet have some firmware problem or are needing of a full factory reset!
Kodi was working perfectly before attempting to upgrade to 17.1 (not realising it wasn't compatible). So reinstalled 16.1 that's when the crash first happened.
I tried a factory reset straight away. With the same result installing 16.1 and ftmc. (crashing after 'first run' screen)
I agree that it must be a problem with the tablet somehow. Just can't work out what.
Originally posted by Maussie View Post
You are after codecinfo. This can be brought onto the screen by pressing 'o' on a keyboard or using smartphone remote app and look up this option in the function library.
On stock remote we juste have to stay clicked on menu button in middle remote to see that. As I see in my S912 TX8 device FTMC use only AMLogic codecs like SPMC.
I dont know how FTMC/SPMC select the codecs it will use.
Originally posted by minixfreak View PostI have found a kodi 17.1 which plays 4k on amlogic devices.... it's under test builds on kodi site ... it's the Droid-ar release (amlogic-release) I'm assuming ... could u look into this superceleron and also they have made kodi 17 work on kit Kat as well ... it's by mygica
About that magica... its a beta build of kodi 17... that they renamed as 17.0... more no binary addons and even more it plays like crap, i know because i test it... i not recommended it....
Originally posted by mikele View PostThis fork run as hell on my AMLogic device TX8 S912 but I dont see many differences with SPMC excepted the startup picture and different mouse move to show the codecs info. FTMC is may be little more stable on my device...
Do you use python 2.7 in FTMC ?
There are currently 2047 users online. 0 members and 2047 guests.
