FTMC Jarvis 16.2.31
    The software is fantastic. I tried it on odroid c1 but the auto refreshing on "adjust on start" switch didn't work. I think there was a hack for amlogic S805 to enable auto refresh rate switching.
      Just found here it is :
      Is it possible to include it for odroid c1 please ?
        updated 1ยบ post...
        Added a new build for Android x86 devices!
          superceleron when I attempt to download the RK ver 28, it appears the link directs it to the x86 version.
          Sent from my SM-N900W8 using Tapatalk
            thks for the heads up.... my mistake, will fix asap!
              Fixed
                No problem .... and much thanks for your hard work.
                  Does this include security fix for subtitles please?
                    Yes new version fix subtitles
                    Andreas
                      hello, how can i change the language to dutch now is only english posible
                        working just fine here, are you sure on 16.2.28!?
                          Hi there I've installed v16.2.28 on top of previous and on system info shows "Build: FTMC 16.1 Build 24" Compiled on March, 4th 2017.
                          Is that just a glitch?
                            superceleron
                            Please find attached a log for Ftmv on odroid c1. As I said the refresh rate is not working.
                            Thanks!
                              Yes but is there aan diference in the download ik installed the general version
                                FTMC changed a lot from 24 to 28... you may need to start over!
                                Originally posted by albsat View Post
                                superceleron
                                Thanks!
                                m8 that is not a FTMC problem, you need to chmod you rom "chmod 0666 /sys/class/display/mode"(you need root) or else it wont work!
