could you please merge this PR to fix the security issue with subtitles?
FTMC Jarvis 16.2.31
Originally posted by 007 View PostHmm weird. I will do a factory reset on my boxes reinstall and report back tomorrow. Maybe something I installed.
What I plan to do is factory reset, fresh install and lll install just exodus nothing else not even indigo.
My boxes are not rooted but I have files from the mfg to root. This can't be the issue though I don't think. Should I root?
One box is rk3368 and other is s905 both 2gb ram
Anyway I will try what I said and report back. Everything else was flawless.
And yes try a clean build and install only exodus!
@superceleron Is it possible to use AMLogic codec with SD movies too ? And how to do it ? I can tweak it with spmc but I do not see the tweak on FTMC. On other hand I can not use spmc because it stop in middle of nowhere sometimes when I try to look any movie where spmc rock solid...Last edited by mikele; 24 May 2017, 15:18.
Originally posted by mikele View Post@superceleron Is it possible to use AMLogic codec with SD movies too ? And how to do it ? I can tweak it with spmc but I do not see the tweak on FTMC. On other hand I can not use spmc because it stop in middle of nowhere sometimes when I try to look any movie where spmc rock solid...
To see if its using, long press the menu button on your remote(or the O key if you have a keyboard) when the video is playing and it should bring the statistics and in there you will see what codec is in use, amc(mediacodec), aml(amlogic) and ffmpeg(cpu).
And no FTMC dont have that setting that SPMC have!
And i think for SD video file CPU is the best!
well you should work on sd movies but not all!
Originally posted by isaack View PostDoes anyone know if FTMC will be updated to address the malicious subtitles vulnerability?
ok tried on 2 more boxes same issue
evererything else flawless.
so if i use exodus to watch a HD movie, stop it exit come back in and go to launch same hd movie using resume ftmc will hang.
this even happens on my ami S905-b
Im not complaining. I find everything else to work great. I also like that it exits quicker than official kodi for some reason. But I think I found a bug.
each time i tested i factory reset the boxes, then installed ftmc 26 then added fusion source, installed indigo, installed exodus
if it is just me this is weird because ive also used it on different hardware.
SOCs i used were RK3368 and S905-B
very diffferent SOC
both android 5.1
both 2gb ram
with the rk3368 i even did it on a brand new out of the box powered on the first time HiMedia H8 Plus, and then I upgraded the firmware to latest build factory reset and try again.
Maybe coincidence that its my specific devices.
I will also be trying it on a Brand new Mygica 1900 pro tonight Ill report back.
Im picking up the mygica in 1 hour but then I gotta wait till after work to test.
Not complaining I love FTMC. Even with the bug.
Ill take a video of my next test and upload it and a log if you like
There are currently 2959 users online. 1 members and 2958 guests.
