LibreELEC is a Linux OS and much more advanced than Android so compatibility is much better for Kodi.
FTMC Jarvis 16.2.31
Kodi addons have lots of trouble with Python on Android and their might be some compatibility problems with the addon.
Can someone see my log file. FTMC build 24 crash. Yesterday all was fine. ......https://pastebin.com/eNisnkEB
Originally posted by xalaros View PostCan someone see my log file. FTMC build 24 crash. Yesterday all was fine. ......https://pastebin.com/eNisnkEB
Also get rid of all those broken addons you have installed.
I have been using quite a lot smb the last weeks and the video stops after sometime, fortunately I can resume te video instantly and it continues playing without any problem. This happens always, tested using different drives. It does not happen in other devices (tested in iOS and Mac OS with Jarvis). Is it a known problem? Next time I'll turn on the complete log to catch anything that could be happening. It is not an important bug, i just wanted to notify about it.
Thanks for your work!
PS: Since I installed "Confluence Zeitgeist" skin FTMC is just amazing.
Originally posted by xalaros View Post1) In RKMC category I have default setting, I didn't change anything. Do I have to deselect all of them in this section?
2) What are these broken addons to uninstall it?
2. All the addons you have installed by the looks of it, then start fresh.
I have an MK8 pro box with stock rom. I had SPMC installed on it. I uninstalled it with Titanium BK, deleted SMPC folder in Android/Data/, then tried FTMC, except that the latter wouldn't install. I currently have no Kodi or any similar Media Center apps on. Previously, I had SC3 rom, and experienced the same problem. When I re-flashed stock, I was careful enough to wipe everything twice with TWRP, including formatting internal storage. So this is very unlikely to be caused by residual data. Does anybody have any idea why?
Hello,
I have Beelink GT1 2/16GB with Superceleron V8C rom.
I have passthrough enabled in FTMC settings and Beelink is connected to the Denon AVR X-1000 through HDMI.
When I watching a movie on DD AC3 and change the volume down in Beelink GT1 then DD AC3 turns off and I hear a crack. When I get volume back then DD returns and everything works fine.
When I change the volume not on the Beelink GT1 only on Denon X-1000 then there is no problem.
I tested Libreelec on my Beelink with Kodi 17. Changing the volume on a Beelink changed the volume on a Denon X-1000 and there were no creaking problems.
Probably to eliminate the problem in FTMC should disable the ability to change the volume on the Android when the passthrough is enabled.
well if i have the time i will look at it, i dont touch in ftmc source in some time and im thinking if i will continue the work on it, to many projects some need to go!
Originally posted by BidonX99 View PostWhen will the full hardware support RK3399? 4k1 (10bit x264) not work
Neither is looking likely right now, at least under Krypton and beyond.
There are currently 2068 users online. 0 members and 2068 guests.
