Sent from my SM-N900W8 using Tapatalk
FTMC Jarvis 16.2.31
Originally posted by m1pnk View PostHey super.... I got a few boxes and family. .... I notice with 30 that if I copy over add ons and use data from my build to another. .... I loose the front page settings like shortcuts. .... was fine with 29..... anything I can alter in settings..... many thanks and love your work.... pinky
Originally posted by f4cdroid View Posthi superceleron, i've a problem with beautifulsoup4 dependence, said "xbmc.python" is missing or not exists, i think because python is trying to find "xbmc.python" and FTMC is named "ftmc.android". Are there any solution?
thanks for your time
your apps/stocks are GREAT!!
thanks superceleron, but i think is the beautifulsoup4 for kodi, don't work fine, it's pending to update, keeping in v4.3.2
Originally posted by maccafan View PostI seemed to have missed this. Is this build any better for RK3188?
I am currently running MyGica Krypton build for 4.4.
If you are using Kodi then you can install FTMC at the same time without it affecting your Kodi installation.
Originally posted by maccafan View PostBetter than Mygica? A Krypton port for 4.4 devices.
My mistake for not reading that correctly.
I would certainly suggest installing FTMC and trying it out to compare.
FTMC is currently based upon Jarvis.
I found a 17.3 Krypton based SPMC fork in its 8th Alpha stage that seems pretty stable, it doesn't have Rockchip specific love like FTMC but it still should be better than stock Kodi. Hopefully a dev as good as Celeron can fork it with some Rockchip specific love.
I don't know anything about what devs like you go through, all I can do is appreciate the work you do. If supporting Android 4 is holding you back on FTMC Krypton in any way, I humbly suggest ditching it (at least for the Rockchip version). Between FTMC, MyGiga, EBMC, NODI, and CEMC and at least few others that don't come to mind right away I think Android 4 is reasonably well covered. Especially given how old it is and how cheap it is to upgrade to a Android 5+ device for Kodi. Amlogic devices already have tons of options that work great too, whats not covered at all is a Krypton based Kodi fork that takes properly takes advantage of Rockchip hardware. Even powerful higher end Rockchip devices are really feeling the affects of being neglected software wise.
Thanks for the info. Will try this and replace MYGICA on my older CR11s and report back.
I am blown away by the speed and smoothness on my old RK3188 device.
I am going to replace Krypton on my newer RK3368 device too. Brilliant.,
Kudos and thanks to the devs for their time and talent. RESPECT!
There are currently 2960 users online. 0 members and 2960 guests.
