The FTMC version I have shows 6.1 .23. Looks like there are updates to this. How can I force an update to FTMC ?
FTMC Jarvis 16.2.31
Thanks a lot superceleron for FTMC. I am able to use an addon which is supported only by kodi17 because they have updated their site to https protocol. I have AVOv onlineplus box with android 4.4.2. I was able to get the FTMC thro mickey hop.
Originally posted by madhat View PostThanks a lot superceleron for FTMC. I am able to use an addon which is supported only by kodi17 because they have updated their site to https protocol. I have AVOv onlineplus box with android 4.4.2. I was able to get the FTMC thro mickey hop.
Other than the News 12 addon from the official Kodi repo (it specifically says Kodi 17 only and I get dependency errors when installing its zip file manually as it won't even show up otherwise), I don't have any problems getting other video addons working to my knowledge. Is there any way to inject just a few Krypton dependencies to get this addon and at least one Krypton skin working? I have a Krypton build using the mimic skin I have worked long and hard on but I can't just drop it on a 16.1 based FTMC due to the incompatible 17.3 skin but I can't just install a 16.1 skin on Krypton either. What I probably need is a skin that is cross compatible with both Krypton and Jarvis if that even exists. Any suggestions?Last edited by Kodimailbox2017; 29 August 2017, 09:17.
Hi
I purchased a H96Max box only to find out that it only output stereo sound and many dropped video frames using Kodi 17.4. The 'video' player app however outputs multichannel sound (DTS, Dolby etc) correctly and smooth picture, no dropped frames. So, there is obviously something wrong with Kodi (system sound settings set to 2.0ch audio passthrough for SPDIF passthrough ... but tried many other audio combinations, including 5.1ch no-passthrough, still only stereo comes out). I was told to try FTMC which I downloaded and installed from this website (Rockship version)... but I still have the same problems with stereo sound only and poor video (jerky). Is anyone using FTMC on a H96Max unit who can give me some advice? Thank you!
There are already RK3399/RK3328 devices with full Kodi 18 compatibility and running Nougat.
There are currently 2183 users online. 1 members and 2182 guests.
