MXQ PRO+ Firmware Download
Originally posted by scooter2014 View Post
Strange way of moderation. You removed my message with the results of me testing the firmware. Also you replace my post text with your own text, not marking it as moderated, making it appear I wrote that message?
Originally posted by paintedrock View PostI also bought an mxq pro+ from gearbest. Looked good on paper. I have all the same problems. At least their is a group forming to try and get a working firmware. what is kind of deceptive about gearbest are the reviews. Every product has 4.5 to 5 stars. Im pretty sure every mxq pro+ that has been sold has these problem, so they have to be writing a bunch of reviews for their own product and deleting some of the bad ones. I knew what their return and refund policy was which is kind of a rip off. They did live up to it. I got half back 22.00 in gear best rewards and gearbest wallet $. So I got a box that restarts about once a day, after i uninstalled/disabled almost every app and system app, exept kodi and es file explore. I used es file explore to download new kodi 16.1. The playstor doesn't work anymore, but you cant download anything anyway. It did make a differance. But is still annoying. So I think there will be a fix eventually, but a couple months down the road. So I got a Mxq pro+ for $22, and have to wait for updated firmware. It isn't worth the time and effort in $ terms, but it is a little side project that is kind of fun. I have an M8s+ (not the mini m8s+) that works really good to watch kodi on in the mean time. I would recommend the m8s+. Both are made by eny. Well thats my experience with this box so far. Some one come up with a fix, it would be appreciated.
About the new firmware: Flashed it on my second (still working) box via amlogic burn tool... and nothing changed as far as i can see. The same bugs... so the manufacturer fooled you gearbest.... just like you fool us with the good reviews...
https://cloud.mail.ru/public/B4vL/JyjxjjS7Q here its the firmware but only wireless have problem. http://4pda.ru/forum/index.php?showt...#entry50045686 1BIGMAN picture
neomode pics are from this review. Check the review for other pertinent info.
The chips on board are:
CPU = Amlogic S905 quad-core
GPU = Mali-450
RAM = 2 GB
16 GB eMMC flash memory = SAMSUNG KLMAG2GEAC-B002
WIFI + Bluetooth = AP6330
Ethernet Transceiver = RTL8211F
USB 2.0 hub controller = MA8601 (although USB 3.0 advertised)
24-bit audio DAC = ES7154
Link to stock firmware: https://mega.nz/#!JtFRTLAT!XE2m7cmuW...3Dpj6OTMFvBK3c
Link to Gearbest provided update firmware: https://drive.google.com/file/d/0B-o...w3UWFmQVE/view
Hope this helps.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
There are currently 2835 users online. 0 members and 2835 guests.
