A quick recap of the steps: root the box, install rashr and recovery reboot, flash twrp in rashr, reboot to twrp and restore the image. All nicely described in the linked pdf.
MXQ PRO+ Firmware Download
fenoamby Use the TWRP method, it might look daunting to a new Android user but I can confirm the SDRobot's firmware works really nice. And you get a rooted box with ad-blocking enabled.
Originally posted by Shimon View Postfenoamby Use the TWRP method, it might look daunting to a new Android user but I can confirm the SDRobot's firmware works really nice. And you get a rooted box with ad-blocking enabled.
but TWRP don't see the file.
Is it this file i must restore with TWRP ?
I don't found the PDF.... :-(
Originally posted by Shimon View PostThe name has been recycled indeed but apparently it's an S905X device now.
Just found this IMG file from Russian Forum (download link above)
*****(http://4pda.ru/forum/index.php?showt...6&st=6900)****
which has been modified for MXQ pro Plus from ***(http://www.freaktab.com/forum/tv-pla...erfast-rom-1-0)
works perfectly fine with my box
Though I have H96 Plus 2/16 gig box which is same as MXQ ProPlus & I have been using MXQ Pro Plus Firmwares as the config is same right now onTronsmart since 6 months,
just upgraded to the new ROM based on Minix U1 FW13
Wifi----- works
TWRP----- Preinstalled
Root------ yes
Remote----working
Kodi------ works fine 17
well no bugs found yet
Disclaimer: The Rom has been developed by Bob originally & tweaked for MXQ by sergej_a_g(Russian forum), I am just passing the links
Originally posted by usernamereg View Post
Well Ours is S905 and I dont think it will work with S905X(BOTH DIFFERENT PROCESSORS), might brick the Box, but may b we can modify nougat rom from this box like tronsmart
Wifi----- works
Root------ yes
Remote----working
Working fine on my MXQ Pro+
There are currently 2387 users online. 0 members and 2387 guests.
