Is your stick running too hot underclocked/undervolting kernels is here
all these kernels have the Frame skipping fix included
underclocking and undervolted available kernels here are
720p CPU 1.2Ghz Ram 1200Mhz GPU 600Mhz kernel
720p CPU 1.2Ghz Ram 1500Mhz GPU 600Mhz kernel
720p CPU 1.4Ghz Ram 1200Mhz GPU 600Mhz kernel
720p CPU 1.6Ghz Ram 1200Mhz GPU 400Mhz kernel
720p CPU 1.6Ghz Ram 1500Mhz GPU 400Mhz kernel
1080p CPU 1.2Ghz Ram 1200Mhz GPU 600Mhz kernel
1080p CPU 1.2Ghz Ram 1500Mhz GPU 600Mhz kernel
1080p CPU 1.4Ghz Ram 1200Mhz GPU 600Mhz kernel
1080p CPU 1.6Ghz Ram 1200Mhz GPU 400Mhz kernel
1080p CPU 1.6Ghz Ram 1500Mhz GPU 400Mhz kernel
all kernels in one RAR download here http://www.cloudstor.es/file/m1_NDcyOA/
Originally posted by sam321 View Postall these kernels have the Frame skipping fix included
1080p CPU 1.4Ghz Ram 1500Mhz GPU 600Mhz kernel.img PLEASE!!!
1080p CPU 1.4Ghz Ram 1500Mhz GPU 600Mhz kernel.img PLEASE!!! sam321 THANKS!!
These kernels are still working very good.
My stick was running too hot and was rebooting under heavy load, but with one of these it's running stable.
So, still a good alternative to try out before butchering your device, adding heatsinks and fans. Especially if you're looking for stability rather than max performance.
The only question is, should I look around for any newer kernel with the same clock values or aren't there enough updates in the newer kernels to warrant an upgrade?
There are currently 3866 users online. 1 members and 3865 guests.
