How to unbrick 3229.
    Hi PaulieP ,
    try it with AndoidTool 2.35 and first erase flash (secondTab) , after that it must work with flashing .
    good luck
    gefattern
    Hi, thanks.
    Actually nothing solved it. Fact is I had to download ROM after ROM online until I found a compatible ROM and it flashed without having any problems at all and it's repeatable - i.e. the problem was mismatch for the PCB despite the ROMs both being for MX4N RK3229 with AP6051.
    But back to the point, yes as far as shorting pins to unbrick, worked great on two different Scischion V88 RK3229's (V88 is a MX4N variant) and flashed without issue on any Rockchip flasher app once I found the right ROM.
    FYI for those having issues flashing to the MA8-4K box, there is no factory rom currently , if you've bricked your only choice is to flash a compatible ROM. .The only compatible ROM that flashes with zero problem are the marshmallow ROMs for the V88 (SV6051 / AP6051 wifi chipset version).
      Hi PaulieP ,
      nice to hear that your Box is back to life , now u know what to do , Backup the image ,
      that this never can happen again .
      good luck
      gefattern
        Hi PaulieP ,
        good luck
        gefattern
        Good afternoon bro, please I need help on how to revive my box v88. I have tried several firmware but not working for my box. It stopped at updating the firmware with red lettering on the flash tool
          Hi bisiking ,
          no Panic RKDevices are nearly unbrickable , i come back in a few hour to you , okay ,
          then we go further . Please give a Link where you bought it , or give all Specs , Ram ,
          Rom , Wifi , write you later .
          greetings gefattern
            Hi again bisiking ,
            does Scooters unbrick Guide from Page 1 not work for you ???
            gefattern
              Hi bisiking ,
              greetings gefattern
              thanks bro.
              SCISHION V88 Android 5.1 4K TV Box RK3229 PK Amlogic S905X Mali-400 1GRAM G eMMC H.265 WiFi Set Top Box 3D Media Player . 1g ram ,8gb rom
                Hi once more .
                first we must search as possible for Stockrom . Please ask your Seller , too
                Look the (((((( ))))) this are different CPUs , is it a RK or AML CPU ???
                SCISHION V88 Android 5.1 4K TV Box ((((RK3229))))) PK (((((Amlogic S905X)))) Mali-400 1GRAM G eMMC H.265 WiFi Set Top Box 3D Media Player . 1g ram ,8gb rom
                greetings
                gefattern
                  Hi again ,
                  look here , but only if we know it is RKDevice . Roms .
                  http://freaktab.com/forum/tv-player-...x-1-8gb-rk3229
                  gefattern
                    Hi once more .
                    greetings
                    gefattern
                    I have tried to contact the seller, not responding to my request.
                      Hi bisiking ,
                      do you know what CPU it is using , maybe u saw it somewhere in an DeviceSpec.App
                      that was on your Box , before it bricked ??? do you know ??? otherwise we can not really
                      go on , or we must test it with the different BurningTool , if you not can or want to look under
                      the Heatsink of your device . I come back later , now i must first do other things .
                      greetings gefattern
                        Hi bisiking ,
                        greetings gefattern
                        Did I need to remove the heatsink? But I think it's processor is rk3239d and it is using sv6051p.( Xt-mx4n-v03) 2017-02-08
                          Hi bisiking ,
                          greetings gefattern
                          Did I need to remove the heatsink? But I think it's processor is rk3229 and it is using sv6051p.( Xt-mx4n-v03) 2017-02-08
                            Hi bisiking ,
                            if u are sure we can go on in a few hours , first do you have Drivers and the Flashtool that are needed ???
                            are Drivers installed ??? Batchtool 1.7 / 1.8 & Androidtool 2.35 & RK Drivers 4.4 . Download over big G .
                            Does the Flashtool find the Device if you connect it to Pc ??? ( connect like you want to flash ) . Important
                            what Windows do you use , always run the Tools as Admin . Please add a Link where you bought it to see
                            more Infos about Device .
                            Please answer my Questions , write you later .
                            gefattern
                              Hi once more ,
                              FW : 5.1
                              Infos : below
                              We have good news, there is a new firmware for SCISHION V88 TV Box with Rockchip RK3229 (update 2016-08-27). This is probably one of the most anticipated
                              FW : 6.0
                              first you have to flash a Stockrom to set all back to correct values . Download and try if the Box can still
                              connected in "LoaderMode" . good luck
                              gefattern
                                Hi bisiking ,
                                gefattern
                                Thanks. The drivers are installed. And the flashtool find the device with both batchtool and androidtool 2.35. Am using windows 7
