How to unbrick 3229.
    Originally posted by baya View Post
    Thanks for the reply gefattern.
    LoaderMode is fine.
    I tried with AV to RCA cable, stuck on green screen.
    I got from a friend dump backup for the same model,( plz check file list)
    what to do ?
    Hi ,
    for this you need AndroidTool (first Tab) , you can select the important .imgs or all and
    flash them , hope you know what i mean ??? otherwise ask . / greetings / gefattern
      @gefattern
      fleshed with dump, but is same result.
      This device is maybe for the rubbish. if i can flash some linux or libreElec, openelec etc.
      let me know. I will not bother you anymore
        @gefattern
        LibreElec only exist for RK3328, RK3288 & RK3399 so far not for RK3229.
          mo123 thx
            mo123 thx
            Hi ,
            did you flash the BackupRom with same Result ??? , i see u not flashed with "loader" img ,
            but well the backup.img , backup is not needed but the Loader well , ever tried , and what
            about booting Android from SDCard , ever tried ???
            look here :
            http://forum.gsmhosting.com/vbb/f906...ualok-1786042/
            here a newer Tool & Link :
            http://chinagadgetsreviews.com/downl...tool-v1-4.html
            Link works , i self loaded the Tool .
            good luck / gefattern
              @gefattern
              yes, same result, Dump Loader couldn't import coz i did not get.
              I have some issue with the micro sd card's or adapter, ill report.
              Found this ROM's, all failed.
                @gefattern
                https://drive.google.com/drive/folde...EhqQUpBSzU3ZE0
                Hi baya ,
                any changes , maybe your Bootloader is bricked , dont even know
                if it is possible .
                  @gefattern
                  Device doesn't turn on anymore. I threw it away.
                  Sorry guys
                  Thank you for your support
                    @gefattern
                    Sorry guys
                    Hi ,
                    do what you want with your Box , next Time buy better supported Box .
                      Dear guys, need some help! My MXQ pro RK 3229 stuck on ROCKCHIP SCREEN like attached file.
                      Box won't boot up. Tried to hold reset (pin in AV slot) then put cable in. Still stuck at ROCKCHIP.
                      Do I have to purchase a MALE-to-MALE A cable or is it possible to revive without buying anything plus?
                      Kind regards
                      Soldiaz
                        Help me out. I want to upgrade v88 and I was getting this error message ' download boot fail '
                          Hi once more ,
                          FW : 5.1
                          Infos : below
                          We have good news, there is a new firmware for SCISHION V88 TV Box with Rockchip RK3229 (update 2016-08-27). This is probably one of the most anticipated
                          FW : 6.0
                          first you have to flash a Stockrom to set all back to correct values . Download and try if the Box can still
                          connected in "LoaderMode" . good luck
                          gefattern
                          Is someone able to guide me through how to flash a stockroom? Thanls
                            Hi ,
                            do you have the right Rom for your Box ???
                            ask if something is unclear / good luck / gefattern
                              I'm not sure if I have the right ROM? Its a MXQ 4K with a rockchip 3229 chip, 6051p wireless and the board is a MX4N-V03. I've had the most luck with V88_RK3229_6.0_MX4N_WIFI Spectek_20170405. I'm trying to find a link to download but everything I try only gets to the "download firmware" and then fail!
                              rk3229_6.0_MX4N_SSV6051p_zhongx_20170405_v009_Spec tek but the only link I can find is dead.
                                Hi everybody,
                                I've two Nexbox A95X bricked, both has the same problem, RED LIGHT and won't turn on.
                                How can I unbrick these boxes?
                                The board is RK3229_D16 1.2 and SV6051P wifi Chip.
                                Can anyone help me?
