How to unbrick 3229.
After reading a lot around here I think I still need help from someone. In that hope here goes....
I have a V88 Mini, with RK3229 & SV6051p wifi and after a few attempts to get some fw working on it the box stop being detected by the pc.
It was being normally detected by the pc and as I was not happy with the box working (2nd fw install) I went for another install. On the last install, all was going great until I got message "download firmware fail". After this the box stopped being detected.
So I think I need to short pins?! But which ones?
Thank you to anyone that might help me.
Originally posted by J_Tech View PostAfter reading a lot around here I think I still need help from someone. In that hope here goes....
i can not exactly say wich one you must short , for RK Boxes most the Pins 7-8 , 8-9 are used ,
but every Chip and Box are different , u must try , maybe here you can find some Infos :
look here too :
and this hopefully helps too :
but u need a working Rom to restore best Stockrom .
greetings / gefattern
Originally posted by gefattern
Hi ,
look here too :
I will check it out and let you all know how it goes.
Sent from my WAS-LX1A using Tapatalk
[.....] no Panic RKDevices are nearly unbrickable [.....]
greetings gefattern
And now I truly believe you. Thank you.
And after all messed up stuff I did to the V88 box, IT LIVES.
Box detail: V88 Mini with RK3229, wifi SV6051p and board states MX4MN-V13.
Short pins are 8 and 9.
Check photo.
Now still only trying to find the best fw for this box
gefattern
Check photo.
once more , look here for FW :
http://freaktab.com/forum/tv-player-...ear-mxq-pro-4k
it is for a 1/8GB Box i think , if it fits , you can try , no guarantee , good luck
Hi ,
Hi ,
so this Rom did not fit 100% i think it is for Realtek 87... Boards , there are right Roms ... ,
check your PCB NR. MN4MN-V13 in big G , first Link shows a 4PDA link to a Rom for
your Box & search here same Way . Would Link it but my 3G Data is slowed down .
... but first they must be found / greetings / gefattern
And when I was ready to say it was time to move on and live without wifi, your words gefattern gave me another boost and following the link to 4PDA, I found this room rk3229_6.0_box_MX4N_SSV6051p_SpecTek_flash-update_20170616.img and decided to try one last time.
And finally wifi works.
ROM with wifi working: rk3229_6.0_box_MX4N_SSV6051p_SpecTek_flash-update_20170616.img
Hi guys,
I think i´ve completely bricked mine RK3229.
Flashed a wrong firmware, so I had to restore it with the maskrom mode.
It worked again, gave it a second try with another firmware, which also did not work.
So I thought it wont be a problem because of the maskrom mode, but the androidtool does not recognize my device anymore..
I installed the drivers.
Any ideas?
Bye
passi0509
There are currently 1423 users online. 0 members and 1423 guests.
