MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
    NEOMODE , for the UG007 there is a fatal video bug in this rom
    The video hardware acceleration doesn't work
    All video applications report that they can't use HW mode , but the hardware acceleration worked
    Very well with your old other rom for MK809III and UG007B
    I tested many times to confirm this result on the UG007B.
      Hi Neomode, I can't seem to find your ROM for the RTL8188ETV wifi chip. Could you please point me in the right direction?
        This is the right Rom in this Tread. Download and Install :-)
        Neomode
          Neomode
          Thanks Neomode,much appreciated! I plan on flashing this and then Sam321's fixed kernel afterwards unless this is a bad idea?
            I think this is a great idea
            My devices:
            Gearbest.com)
              Neomode ROM + Strauzo's Kernel
              Neomode I am using your ROM combo with strauzo's kernel (720). It is absolute amazing how smooth everything works. The playback of video using wifi from nas server is perfect (you have to adjust the dongle to see the access point) ! And there is not any overheat problem although I live in a very warm country (rhodos Island - Greece)there isn't any freezing of the system.
              I think a new combo ROM version of you and strauzo will help a lot of people .
              Do you know if it could be a 1080 kernel???
              Thank you very much again.
                RE: MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
                Neomode, I have a big request can you return back the mouse 'scroll wheel zoom' from settings menu, which was в мк802 III, will be nice .
                .. and the 'Screenshot' button if it is posible .. thanks Neomode for this ROM .. work nice.
                  Someone is having problems with mx player these days? I will not play anything
                    AW: MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
                    Working on a new Version of this Rom with Frame Skipping fixed Kernel.
                    Hope to release it soon.
                    Neomode
                      RE
                      Do not forget for
                        Me too
                        Originally posted by ScopeX View Post
                        Great! Herzlichen Dank Neomode!
                        If have one more issue. I can't use a USB Stick or an external HDD when I plug it in after the system is started (although I get the "save remove" info). I already tried different explorers and klicked "reload". After restarting the system the Sticks and external HDD work fine.
                        Thanks and best regards
                        Sven
                        Me too. I dont get it. I get it on both full size and mini usb.
                          Please don't forget to USB LAN adapter (driver)ThanksBojan
                            Will there be a updated Custom Rom for the "old" version of the MK802IV?
                            Thanks!
                              Thanks!
                              i need it too
                                Originally posted by Leandro View Post
                                i need it too
                                I am also eagerly awaiting an update! I am currently running a rom I pieced together from Noemode, the stock June 20 firmware and Sam321's no overclock 720p kernel. I did this to get Netflix working and fix the video playback micro-stutter.
                                mk802iv_20130620_VideoMicroStutterFix.rar (439.7 MB)
                                You should be able to replace the kernel with any of the flavors Sam321 has compiled here
                                Important to note that this is for the older MK802IV with RTL8188 Wifi chip.
