MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
These two were just taken:
Judging from the number of wifi networks using channel 1, I would say that they had the same idea you did. Should I change to channel 3?
Still detecting all my neighbours wifi networks
The last 5 tests, from 16:03 to 16:14, were made after I changed to channel 1
I think it worked, many thanks!!!!
Ok, thank you so much
I think channel 14 ain't supported, it doesn't show on the router channel list.
Edit: Just made another wifi speedtest, download speed has dropped to
1.78mbps...If I disconnect and connect again it will go back to 12mbps
Edit 2: Changed to channel 9, so far it seems to be working okLast edited by BrunoNRG; 21 June 2013, 17:14.
Originally posted by neomode View PostO.k some News on the SDK2 System.img.
It Boot´s but no Wifi and Bluetooth.
Keep on Working for it.
Neomode
Thanks for your nice work on this.
Originally posted by neomode View PostThanks good to know. But i want WiFi get to Work.
When i have a Rom that Boot and Work you can Test it.
Can you gave me the Driver you use for your Ethernet Adapter ?
Neomode
I did dmesg and lsusb. Here are the excerpts:
http://pastebin.com/uKBrqRxC
Btw, this adapter works well with reasonable speeds (~10 Mbps). I haven't tried static IP, but DHCP works well.
There are currently 1547 users online. 0 members and 1547 guests.
