This rom still has the micro jitter problem when playing videos. I've lost hope that a fix will ever be available. MK802 iv will be **** bound. Ill pick a rasberry pi instead.
MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
Wifi improved, when compared to 4.2.2 official firmware, but on 4.1.1 was even better, instead of dropping to 1/2mbps a few minutes after connecting, now drops to 4/5mbps, on 4.1.1 I get a stable 12/15mbps download speed. Appart from that, it would be nice to see the screenshot function or similar app added and a way to install cwm, everything else I use is working great and with very good system performance.
Great job neo!
Just wanted to chime in and thank you, Neomode, for the improved ROM and your hard work. The new upload unpacked and flashed without issue. Working great so far, except for Netflix... which is an issue I've had since day one.
If anyone out there has had success getting netflix to work reliably, can you point me in the right direction please?
You can help me with it.
Take Ultra Explorer and go to /data/apps/com.netfilx and send me the xml file
that you find there to my Mail Adress.
[email protected]
Thank You
Neomode
Originally posted by neomode View PostHallo,
Ja dies sollte ohne Probleme gehen. Falls du insgesammt zu wenig Speicher angezeigt
bekommst nach dem Flashen sage es mir.
Es sollte aber alles glatt gehen.
Neomode
many thx for the replay in german, i will try on sunday to flash the stick, is there anywhere a step by step howto flash the stick? in the archive i only found the costum rom and the drivers...
thx...
I dont think so, for me WiFi Works o.k. But i keep on Working for a Solution for the WiFi.
I have different AP in the House and will try all of it, because they are from different Manufactors.
Will see if i can this Sideeffect you Talk about.
By the Way let me ask, have you try the Software Wifi Analyzer to see if all is ok.
Sometimes it can help to change the Chanel.
Neomode
Originally posted by neomode View PostRight now i dont have notice any Jitter.
When I ran Netflix it crashed on loading.
Originally posted by neomode View PostI dont think so, for me WiFi Works o.k. But i keep on Working for a Solution for the WiFi.
Neomode
(I don't know if this helps), and the internet service I have is a 15mbps connection.
I use Wifi Analyzer, results are not always the same, as well as the recommended wifi channel...
These two screenshots where taken on 4.1.1 ofw
It can detect many wifi connections
My home wifi is Defcon6, signal strenght is always excelent / full bars, but speed drops from 12/15 to 4/5mbps (sometimes even less) after a few minutes of connection. I don't think this is a router problem, all other devices (2 android smartphones [I think we have the same phone: Samsung gt-i9305], 2 laptops, 1 ps3) I have at home work perfectly and get a constant download / upload speed, and also did the mk802iv but only on 4.1.1 ofw.
There are currently 2793 users online. 1 members and 2792 guests.
