MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
    Warning !
    All new MK802IV with Production Date 07/2013 have a new WiFi and Bluetooth Chip. This means my Rom will work but no WiFi and Bluetooth. The Custom Rom for this you find here:
    Guys here it is the New Custom Rom for the MK802 IV.
    This Rom is not based on the RKM Firmware.
    I took an other System. img Customized it to Work.
    This Rom has a Custom 720p Kernel Tweaked for Performance,
    all Credits for this Kernel goes to Sam321.
    The Boot Animation is from Tatty.
    Thanks Buddys !!
    What is Working:
    Everything incl.
    Bluetooth Full Work (You can pair and use your Device)
    WiFi works Stable
    External Camera Support for Skype tested with Logitech C250
    WiFi Streaming
    Netflix Fix Experimental
    What is Included:
    SuperSU Full Root
    Android TV Launcher Build by myself.
    Ultra Explorer
    YouTube GTV
    Chrome
    Reboot App
    BlackScreen App
    Download here:
    Flash instructions here:
    Regards
    Neomode
    Hi neomode, thank you very much for creating the rom, your efforts are very much appreciated?
    Does this rom have the same video jitter issue which seems to affect all the rk3188 sticks?
    I will try to flash it over the weekend.
      Right now i dont have notice any Jitter.
      Please try it and see ;-)
      Neomode
        That's excellent. Will let you know.
          Thanks for your hard work neo!
          I can't wait to try this rom, downloading...
          If I want to use other overclocked kernel from sam, is it possible with this rom without affecting wifi or bt?
            Yes this will Work.
            I use a 720p Kernel because with this you get the best Performance.
            When the First Rom´s come Build with the New Rockchip SDK 2.0 we should also
            get a good Performance on FullHD.
            Neomode
              I also intend to use a 720p kernel, the one with extreme overclock, I have my mk802iv on a casemod with additional cooling. I've been using that kernel for the past 2 days with your mk809iii custom rom and performance is great, almost 19000 on antutu 55.8 on epic citadel
                Zip errors
                Neomode,
                First off, thank you very much for all of your hard work! I have downloaded this ROM twice, and have received errors opening the zip file twice now. Is anyone else having this issue?
                  Is anybody else having trouble extracting this with WinRAR downloaded file size is 280 MB
                    AW: MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
                    Sam try it with Izarc.
                    I use a Mac I think WinRaR has a Problem with it.
                    Neomode
                      Same here, error extracting zip file, with either WinRar or Izarc
                        No Izarc does not work it says ---------------------------
                        Information
                        Bad zip header found.
                        Continue anyway?
                        Yes No
                          UNABLE TO EXTRACT WINRAR.
                          I ALSO AM HAVING TROUBLE EXTRACTING THE RAR FILE AS WELL. IV USED 7ZIP & WINRAR & IZARC. IT KEEPS SAYING CORUPT FILE. GUTTED. CAN YOU PLEASE RE UPLOAD PLEASE. THANK YOU. PS. Thank you for your hard work.
                            I have Repack it and Upload it again right now.
                            Hope it Works then.
                              Neo is the download link for the repacked zip file the same that is on the first post?
                              Edit: Zip file extraction complete without errors, now flashing...
                              Looking very good so far (still no screenshot function so I took the photo with my cellphone)
                              I'm using sam321 720p extreme overclock kernel, wifi also seems stable
                              Thanks neo!!!!
