NEXBOX A95X Firmware
    drop down notification does not work and cant see bottom keys like the home key and volume keys.
      Yes that is terrible....I hate it when they remove them...trying to get a workaround...systemui is where it is rendered. I was able to take one from another rom on another box but haven't found one for this one.
        Hi.
        On this website explains that you can replace the SystemUI.apk. (page 104) But I'm not registered and can not download it.
        This link indicates that you can take the SystemUI of M8S + / M8S AMLogic 812 Plus Android 5.1.1
        Could you help me?
        Thank you.
          Originally posted by Apasionati View Post
          Hi.
          Could you help me?
          Thank you.
          http://4pda.ru/forum/index.php?showt...#entry48861331
          Here you go.
            Let us know if it works....good find if it does
              It doesn't work for me.
                Thank you guys. You are in the right path,but that apk does not work. I will keep looking and hope I will find it. If i do I will share. Thanks again
                  qemu.hw.mainkeys=1 I forgot....this has to be added to build.prop...if it booted tgis might be all that is needed
                    I am knew to this, do youadd this to theapk you sent before and how do yyou installit. TThanks
                      Seen post someone flashed on 905x. Cant find one firmware for 905x is this board 212?? I try on crap box if someone was able to flash on 905x
                        qemu.hw.mainkeys=0 doesn't work
                          after I replaced SystemUI.apk there is only a black screen...no wallpaper
                            I decided to make a custom Build of this Rom , Have a look.
                            KodiLoaded-A95X-Custom Firmware - Based on build-A95X-201606011847
                              H.mm is this board 212?? Maybe i can try on the Tanix model?
                                Working on porting over a rom as well. I have wifi working but slow and Ethernet is not working. I have some questions to real developers just waiting o reply for help. Way better then stock
