NEXBOX A95X Firmware
Originally posted by liviufedur View Posthere is the SystemUI with navbar and status
a friend of mine has an M8s+(s812- 5.1.1) and we tried your systemui.apk
the result is that now we have the up bar(status bar) but not the navigation bar(down bar)
we also tried the "RUSSIAN" systemui.apk , WITHOUT ANY LUCK!
so any suggestion for your systemui.apk?
do we have to change or add something in build.prop ro work?
can you even" fix" it for us?
any help will be appreciated!
thank you!
Sorry I didn't notice that the thread got moved to the wrong area. Asked for them to move to the non x area. Hope you enjoy the tronsmart port. Several alternatives are available now.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Does anyone have any idea why when you edit the firmware for this box in the Amlogic firmware builder then repack .img root seems to be lost most of the time ?
UPDATE: Apparently this is only happening in the Tronsmart ported rom, Even if you just unpack and repack not touching anything root is gone.Last edited by KodiLoaded; 17 August 2016, 01:51.
Originally posted by MrB010 View PostNEXBOX A95X (S905X CPU) Android 6.0 TV Box has 3 settings (RAM+ROM: 1+8G, 2+8G, 2+16G), so the firmwares are different. Click to download:
Firmware for NEXBOX A95X (S905X, 1+8G)
Firmware for NEXBOX A95X (S905X, 2+8G)
Firmware for NEXBOX A95X (S905X, 2+16G)
source: http://www.inexbox.com/download-andr...x-coming-soon/Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Have to check but think because all the firmware is unified the sotware on most check to see if one or 2 gig model only then install as per same. If you pull up the last log in recovery it should show if it check for the 1 or 2 gig...Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by prahjister View Post
Appreciate the heads up but that is for the s905x. I wish they didn't have the same name
I hope this is of any help.
source: http://www.tvboxnews.com/nexbox-a95x...d-s905-tv-box/
There are currently 1907 users online. 0 members and 1907 guests.
