Pipo M9 Max 4.2.2 RileyROM 1.6
    This is based on the 6/8/13 firmware update released by Pipo.
    This ROM is:
    Rooted
    Debloated
    Init.d support
    Busybox links added
    2, 4, 6, 8 or 12 gig user app space by choosing the appropriate parameter file.
    Working CWM Recovery
    Thanks to:
    Tattman65 for his boot animation graphics
    Petrus for Reboot.apk
    900Supersport for his flash tool
    Fun for his CWM Recovery
    There is the link to the download page:
    Download
    If this is the first time you are flashing one of our ROM's, you may encounter some challenges in installing Windows drivers. Please download this First Time User Guide to help you throught he process:
    Download
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Randy
    Working Great
    Thanks for the great rom, tested for almost 8hrs, no bug found yet...
      Re: Pipo M9 Max 4.2.2 RileyROM 1.6
      Excellent!!!! Glad to hear.
      Sent from my M8 pro
      Randy
        Hello, rrileypm
        At first, Thanks for Your great work and Your Firmware. Installation is easy and takes a few minutes.
        By the way, I and other users from Russia, have such bug as - Wi-Fi doesn't wotk, If Bluetooth will be turned - Transfering Data is not going via Wi-Fi. I should Off and then On Wi-Fi to fix Transfering Data.
        This problem is also consist in Official Firmware based on 4.2.2
        Can it be fixed by You or we should for another new official firmware?
          I'm afraid if the problem exists in the official firmware, I can't do anything with it. Hopefully Pipo will fix this in the next release. That is a problem that needs to be reported to their customer service.
          Randy
          Randy
            Thanks for report, Randy
            I've already wrote about this by E-mail. Waiting for response.
            Dmitriy
              Netflix ?
              Hi Randy,
              Thank you for the work you're doing!
              I just wonder whether Netflix is good now. Have anybody tried Netflix with this new Rom?
              Thank you!
                pipo launcher
                Is it possible to have stock pipo launcher in extra flashable zip?
                  In order to use the Pipo Launcher you must have a code from Pipo. The only way to get this code is by sending an email to Pipo. That's why I don't include it. I could send it to you, but it would basically mean putting all of the bloatware back into the ROM.
                  Randy
                    Thanks for the answer. Well, yes I would like to have pipo blotware as an option to flash on my tablet.
                      I don't normally do this...but for the sake of a happy Freaktab member, I did upload all of the apps I removed from the M9. This zip comes from the M9 3G version, but I think the apps are identical in both versions. There is one app, ProductCertificateService.apk which must be present to decode everything.
                      First of all, here is the person you need to email to get the code [email protected]
                      Here is the link to download a zip file containing the bloatware:
                      Download
                      I think all you need to do is copy these apps into system/app. There might not be enough room for all of them, because I added some apps for rooting, so pick and choose which apps you really want. You might need to experiment with permissions. Some apps need execute permissions, but others don't. Just copy the zip file to your internal sd card and then copy them to the system with a file manager that works in root. (ES File Explorer or X-plore).
                      I do not have an M9 to test this on, nor do I have the time right now to do so. I'm working on other ROM's at the moment. You might need to download and install the official firmware package to see how it is set up...then implement the changes in my ROM.
                      Randy
                        Yes, that or [email protected] - you'll need to supply your tablets serial number. It should be on your warranty card, and hopefully on the back of your tablets. From this they generate a unique licence key.
                        Not sure why Pipo does this, but its probably due to commercial licencing & redistribution of some of the bundled "bloatware".
                        Support your local flasher
                        Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
                          OK Riley , thanks for the zip.
                            Cant wait To try
                            Hi
                            many thanks for the Rom - getting mine on Friday - cant wait to flash your rom mate
                            keep up the good work
                            cheers
                            Shu
                              Perfect
                              After 2 days of using this ROM I can state that everything what I need works perfect. Thanks
