Pipo M9 Max 4.2.2 RileyROM 1.6
Originally posted by rrileypm View PostAfter you flash...how far are you getting.
You see the Pipo kernel boot logo?
Do you see a static slide of the boot animation?
Does it get to the boot animation?
How far does it get?
This will help me troubleshoot.
Randy
first time it boot all the way to android where i can use the table but if i reboot. it get stuck in the first boot logo not the badge nor the one with the blinking lights.
this is using your rom 1.6
What method are you using to reboot? Are you attempting to reboot to recovery with the reboot app?
If so, and you have the stock recovery flashed...this will happen every time. It writes code to misc.img that makes the tablet boot to recovery.
RandyRandy
Originally posted by pr0xZen View PostFair point. But does it boot to recovery by default now? or "just" bootlooping?
but if i decide to reboot or power on. it just stuck on the boot logo.
Which boot logo? Pipo or RileyRom?
RandyRandy
Originally posted by rrileypm View PostWhat method are you using to reboot? Are you attempting to reboot to recovery with the reboot app?
Randy
if i reboot to recovery. it would do it just that when a select the boot system it got stuck in the boot logo
The Badge screen or the Artwork? Is it animated or not. This info helps me know where to look.
How about trying 1.7?
RandyRandy
Buried somewhere in this thread is the link to it.
Go ahead an download and flash it. If I need to make changes, I would rather work on the current ROM. instead of backtracking.
RandyRandy
Originally posted by rrileypm View PostBuried somewhere in this thread is the link to it.
Randy
i spoke to soon it did boot finally.
try 2 times (boot) and it did work like it it supposed to.
third time it fail.give me some note pad error have to press the reset button, an now get stock on the artwork blinking light.
fourth time. the same, stuck at boot logo artwork blinking one.
i do believe i have a defect it unit.
Answering the earlier question there is an old pcb version of the M9. That could possibly be the problem.
RandyRandy
There are currently 2679 users online. 2 members and 2677 guests.
