HOW TO FLASH A CUSTOM ROM
Originally posted by wiiguy View Postcan i flash strauzz kernel after i flashed the rom, or does it have to be all @ the same time ?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Is there any alternate way to flash? using the micro sd?
15th of july i bought an 802iv. From the day one I upgraded to the official newest version(sn/20130602710). The above procedure was ok.
Now I tried to do the same but the procedure with the reset button and the OTG doesn't work. There isn't any response from the pc and believe me I tried it to several pcs.
I finally opened it to ensure that I was pressing right the switch but the result is just same NOTHING Happens on PC. I tried several cables. I tried to shortcircuit the switch (i am not sure if I did it right) but nothing.
My MK802IV stills working with the latest rom in it.
What could I do??? Do I have a hardware failure?
Unfortunately It doesn't work!!!
I tried it after the su reboot bootloader the ricomagic automatically went black like shutdown. I tried the rest of the procedure but NOTHING. There is no connectivity with pc ... just nothing like you don't connect anything.
Is there any diagnostic tool to check my 802Iv???
I am also an onwer of 802iiis which works perfeclty 6 months now. I have upadated itseveral times.
Any Ideas???? or just hardware failure????
The ricomagic 802iv works just fine on TV.
Let me ask how do you do it ?
Did you Power Up your Stick with the USB OTG Cable coming from a PC or with the Power Supply ?
When you do it with the Power Supply typing in the commands I gave you disconnect it and go to the PC and Reconnect it, your Device Boot´s Up in normal Mode and not in Flash Mode.
Make Sense?
Neomode
I'm trying to flash my MK809III since about 3 hours now and no success. Where am I failing?
I hc downloaded Neomode's 1.5 FW from this thread http://www.freaktab.com/showthread.p...loudnet-Go-CR9
and got my stick into flash mode by pushing reset while booting with OTG (I tried several different micro-USB <=> USB cables) on my laptop (WIN 7 enterprise). Running RKAndroidTool.exe as admin and erasing IDB went all fine. But when I want to flash by pressing "RUN", the following message come up:
"test device failed" and "RUN failed". Please see attached logfile.
Do you have any idea what I can do or what goes wrong? Stick doesn't boot in normal mode anymore;-(
Do I need a special UTG cable?Attached Files
You don't need a special cable. Try the follow step by step.
First press Erase IDB
Then try it with an different USB Port
If this also not work you can try to have him extra power.
Bring it to flash mode. When you in flash mode connect your power supply for the stick to the DC port of your stick.
Neomode
Send from my Mobile
There are currently 2394 users online. 1 members and 2393 guests.
