HOW TO FLASH A CUSTOM ROM
Originally posted by neomode View PostHere are Instruction´s how to Flash a Custom Rom:
Neomode
Sent from my Nexus 7 using Tapatalk 4
Edit: My apologies. I see the image now. Have always used Tapatalk here... Not always to good effect.Last edited by mechaone; 05 January 2014, 06:19.Please post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
I have MK802 IV ,and i had problem conectinig to internet,one day ok ,with breaking conection ,next day no chance.
on him was instaled android 4.2.2
so i reed your post,
MK802 IV NEOTV CR 1.0 Neomode Custom Rom 4.2.2
and download it
and
and did as described,and repeat it few times
Problem is after run is completed i disconnect usb cable from otg port and connect it to tv..and after 10-30 min nothing
only screen with black android,neotv cr 10,freaktab
what am i doing wrong please help
regards
Ermo
Originally posted by ermo1 View PostProblem is after run is completed i disconnect usb cable from otg port and connect it to tv..and after 10-30 min nothing
Flash stick using otg port, after flash is finished leave it connected to the pc & let the stick boot UP & wait 5 min after boot then shut it down disconnect it from the otg port & connect it to the dc power port & it should boot up.Please consider making a Donation to freakTab
Originally posted by blinkone View PostHi there did you let the stick boot up & settle down (wait 5 min) after you flashed befor you disconnected it from your pc.
stays onley on home screan..
i will try other pc do the seme..maybe is pc..
sometime when i do run i got eror on data...bat then i reapet proces and its ok..seys run ok
Originally posted by ermo1 View Postyea i did ...10 mins on usb concted to otg..and when i conected it to tv leave it 30 mins ...nothing
sometime when i do run i got eror on data...bat then i reapet proces and its ok..seys run okPlease consider making a Donation to freakTab
Originally posted by ermo1 View Postyou mean hold restet button..Please consider making a Donation to freakTab
Originally posted by ermo1 View Posti will try this now
thanksPlease consider making a Donation to freakTab
Originally posted by ermo1 View PostAAAAAAA
all now ok with instalation and start.....but now in setings wont turn on wf-fi or bluetooth...
aaaaaaaaa
i am noob at this..am i making some mistake...
If wifi & Bluetooth still wont turn on then you have the wrong kernel for your wifi chip.you could either try flashing another rom or just flash another kernel till you find one that works for you & your doing nothing wrong theres so many variations of the tv stick its just a matter of finding the right ones for you
Edit That's a old rom your fashing why not try a more up to date rom
Last edited by blinkone; 05 January 2014, 14:02.Please consider making a Donation to freakTab
Originally posted by blinkone View PostTry this, reboot your stick & then try to turn on wifi & Bluetooth
AND WI-FI SAME BUT AFTER 10SEC..
CAN YOU GIVE ME A LINK
Originally posted by ermo1 View PostSAME WHEN I CLICK ON BLUETOOTH IT'S AUTOMATICALLY DECLICK IT..
There are currently 2175 users online. 2 members and 2173 guests.
