Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
    Originally posted by KAA View Post
    my way
    OIC pretty neat , I like how you have the box stood on its side the Awise didn't come with a stand. i didn't even realize that's what you meant. .
      i use this for stand
      MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
        I should have looked at the picture better , that's one idea I might have make use of.
          my way
          and how did you mount
          heatsink to the board/proc/pcb?
          Want to buy me a BEEEEER?
            Box opening very tight fit for the heat sink.. and rest on top existing metal plate..
            next project .. I want to replace metal plate to alum plate
            inside the box with heatsink stick on top
              Any thoughts of getting rid of the plate altogether?
              I almost didn't remove mine but the really thick pad between the S912 and the plate (Aw S92) kept the metal plate spaced well above any other components as well as blocked access to them.
              I have some small 9mm square and 11X9mm sinks that I planned to put on the ram chips. But apparently are hiding somewhere in my mad scientist lab were processors, rc heli's and equipment, motorcycles, ATV engines ,etc all meet.
              ​I do have some 20x11x5mm, 40X40X10mm, and more 9X9X5mm sinks on the way as well as some adhesive thermal paste and tape. Ended up ordering many of each since shipping costs more than the chips. ​​
                After seeing a mention of a 3rd USB port available on the PCB of the GT1 (Q201), I did some checking of my own and sure enough there it is just to the left of where the front most USB port is soldered on.
                I can guess the orientation of the spare port due to a small resistor, on both the used and the spare port , running to a common trace.
                Has anyone verified the orientation of this port ( which is pin 1)?
                I plan to hook up a small 5v fan internally to this port. Before I run the board unboxed doing live probing to find/ verify +5v and ground, I wanted to check and see if any one had already done so.
                thanks
                d§b
                  I have had a good read through the thread and would like the general consensus on if this is a good purchase now in its current state for Kodi 17.1.
                    I have Logitech Harmony 650 found the Beelink in the database but when I power off it would not. It stays at power, sleep or reboot. Found a tweak in Russian forum 4pda to edit remote.conf but no luck. Any advise?
                    Sent from my Lenovo P1a42 using Tapatalk
                      I have this tv box (2GB/32GB) for about a month now, no problems so far, games, movies, wifi, all work great. I made a video about it if someone is interested, here it is: https://www.youtube.com/watch?v=fxZbNWSVIFo
                        I received this box not even a week.
                        Everything seems to run just fine, Kodi, Youtube, Stremio etc but I must say the followig:
                        - My box cpu is 100Mhz to 1.5Ghz and not 2.0Ghz and I was lead to believe and which was one of the main reasonm I choose this box.
                        - Its sitting right next to my router but can't find my wi-fi connection and does find my neighbors which are all from same company. All remaining devices at home (TV's tablets, smartphones, homecinema) find the connections without any problem
                        - The remote control is just for the dumb to stare as its completly wortless. I'm using a wireless mouse and keyboard which work perfect, and very usefull in reading mode and when scrolling pages.
                        Sent several emails to Beelink and not a single reply.
                        My oppinion, if you know exactly what you are buying, just buy, if you are expecting a box with the advertised specs, go for another box.
                        I'm absolutly sorry for not buying the Xiaomi box which was just €15 more....
                          I had the same problem with my wifi, you need to change the channel your rooter uses, i changed mine from 13 to 3, try it, it will likely fix the problem.
                            PERFECT!!!!!!
                            Thank you very much. I was also on channel 13 (auto) and change to channel 11 and now its working great
                              Can you suggest any APK, to reboot, and switch off, with SW, on GT1?
