Updating is personal choice - there is always a small risk. Follow the correct procedure and 99% of the time it will be successful. I did as I wanted root - in my case I updated no issue at all.
Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Originally posted by jaivelu View Post
Updating is personal choice - there is always a small risk. Follow the correct procedure and 99% of the time it will be successful. I did as I wanted root - in my case I updated no issue at all.Last edited by sesdave; 05 October 2016, 06:38.
Originally posted by sandog View PostAnyone Know how to get it to power on if holding reset doesnt workLast edited by sesdave; 05 October 2016, 06:46.
Originally posted by ASW1Beelink GT1 firmware download:
https://mega.nz/#F!bIVGFaKY!Om3XTxlHmjPB4x2_jukFYw
The Video Tutorial please refer to:
Thanks,but it is not IMG file,it is OTA update when your android works.If your box can not enter into android ,then this solution will not work.
I can not enter into android, and need IMG file for recovery via sd card,or i can use some, or all of this files and go to pin hole recovery menu and to sellect some of this files?
Originally posted by sesdave View Post
I am sure you already have but have you checked the supplied power plug is still working. Its a fairly common connector - one of your other box leads should fit. The MXIII one does. If you have power light on and it wont boot either normally or into recovery sounds like its hard bricked.! If you can get hold of a GT1 firmware img file you could try USB burning tool from the PC. Best of luck.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Yes I tried another power adapter and also tried another box with the same adapterLast edited by sesdave; 05 October 2016, 14:16.
Originally posted by sesdave View PostExtract the files to SD card and boot using toothpick. It should install the firmware . The linked update OTA zip is over 500MBs - I would say thats the full firmware not just add on for existing firmware. I havent tried doing this as I have a running updated system but if it was corrupted during update I would.
Also does anyone know what to pins to short on the chip?Last edited by sandog; 05 October 2016, 16:48.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
so just format to fat32 and extract rar to root of sd.. I dont need to make the sd bootable or anything?
Just any pin to insert into the hole on the backside and press it when you plugging the power cord into the power in of the tv box.
Just follow the video in the previous posts.
Originally posted by vrwmiaris View PostThose of you, being on latest fw are you having high temp issues? How's compared to the fw came out of the box?
Στάλθηκε από το Broken powered G2 D802 μου
Dont know if the the lastest firmware made temp any higher but as the box has run relatively hot since I got it I drilled 9 small holes in the back where the large heatplate is situated and a few others round the base cover- similar to what previous poster suggested. As I had no thermal pads also replaced the pink thermal paste on the heatsink with some artic cooling paste(will replace with thermal pad when I get some) Made a big defference as it definatley runs a lot cooler. Suprised that Beelink didnt have some cooling holes as standard design on the box.
There are currently 1672 users online. 0 members and 1672 guests.
