Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Originally posted by bigall123 View PostI am going to wait for a good rom to come down the line for this box. I think that's the problem at the moment. Its still a new box witch need some tweaks.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Yes but with the Beelink GT1 i think there is some heat issues. Mine gets quite hot after a wile. Im still waiting for my 1" by 5mm heat sink & thermal pads to arrive. PS. I no but im all so on about the acemax box that i have as well. The ace max box is a solid build box, But SBMC crashes all lot on this box as well. As for SBMC being on the Beelink box, Iv had no issues with it. So it must be a software problem.
Originally posted by bigall123 View PostI tell you wot. I did not notice till yesterday. I have my beelink gt1 connected to my 1080p projector, & i have noticed that while in kodi, it seems very dark. Its the same with my Acmax box as well. Is it like that on the s905 box as well. I have tried the newer version of S.B.M.C & the pic is grate but it keeps crashing all the time. Any suggestions any one. Thanks.
Originally posted by sogg View Post
Same issue for me, Dark Picture with the GT1 and also crashing with SPMC. No issues with any of my other S905 boxes, so not sure if its a s912 issue or a issue specific to the GT1.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
Well here is my heat issue mods i have done to the beelink GT1. I have gone down the road of using thermal pads because the metal plate on the bottom base will conduct heat a bit better due to the thickness of the plate. Here are some pics. sorry, It wont let me upload pics it keeps saying that, extension of this file did not match the content.... Any way. I have put 1" by 1mm thermal pad on the underside of the heat shield & the same on top of the heat shield & the thermal pads are defiantly touching the metal plate. I have all so drilled 4 3mm holes in the bottom cover for a bit of air to get in. I have put larger feet on the bottom for circulation. Don't worry about the holes in the bottom because you will never see them.
Originally posted by bigall123 View PostWell here is my heat issue mods i have done to the beelink GT1. I have gone down the road of using thermal pads because the metal plate on the bottom base will conduct heat a bit better due to the thickness of the plate. Here are some pics. sorry, It wont let me upload pics it keeps saying that, extension of this file did not match the content.... Any way. I have put 1" by 1mm thermal pad on the underside of the heat shield & the same on top of the heat shield & the thermal pads are defiantly touching the metal plate. I have all so drilled 4 3mm holes in the bottom cover for a bit of air to get in. I have put larger feet on the bottom for circulation. Don't worry about the holes in the bottom because you will never see them.
Originally posted by jonahy View PostGot this box last week from gearbest runs fine on most android apps.
OTA updated from September firmware. crushed once when i watch Youtube (frozen ) .
But Kodi come with the box gave me Video playback micro-stuttes (720p 1080p), should i try spmc or disabled libstagefright maybe?
https://github.com/koying/SPMC/wiki/...-Nvidia-Shield)Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
There are currently 1618 users online. 1 members and 1617 guests.
