Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
    Originally posted by tenoce
    New OTA hangs, anytime I try. Is there a usb update file?
    Rmove usb stick and try again
    Odoslané z Redmi Note 2 pomocou Tapatalku
      There was no usb stick attached.
        Is there any coupon available?
        Στάλθηκε από το Broken powered G2 D802 μου
          SD card?
            I'm getting a error when I try and update.. Anyone have a link for the firmware to download to flash it with the usb tool or sd card
            Nvidia Sheild Tv
            ADT-1 Developer Kit
            Wetek Core
            Fire Tv2
            Beelink GT1
            Raspberry Pi2
            Odroid C2
            Nexbox A5
              With the last update my box is stucked at boot logo....i have to unplug and plug several times to make it work
              Sent from my MX4 using Tapatalk
                Two days before, I got the Beelink GT1 and it worked very well in the default factory firmware. I don't want to update the box even-though update is available!
                When playing the 10 Bit HEVC files the screen goes green, but the sound is good! Otherwise everything works very well including wifi!
                When everything works very well out of the box, then why bother to update it!
                So, I'll only update the tv box, once all the glitches are fixed, until then "root access" is not a big deal for me!
                  I updated my GT1 used it for a few hours. the next day I plugged the power cord back in and now noting wont even power up
                  Nvidia Sheild Tv
                  ADT-1 Developer Kit
                  Wetek Core
                  Fire Tv2
                  Beelink GT1
                  Raspberry Pi2
                  Odroid C2
                  Nexbox A5
                    That's why I have been advising not to update the Beelink GT1.
                    Don't update the Beelink GT1.
                    Please use it with factory default firmware.
                    If any problem, reset the box. If you turn over, at the bottom of box, there is an hole is there. Press it with a prick and reset to factory defaults.
                    You won't have any major problems with factory default.
                      Thank you,but if we update the firmware,can we go back with the process you ve described?
                      Sent from my iPad using Tapatalk Pro
                        Yes for most common problems, resetting the box will work.
                        But at the moment the updates are creating lot of problems including the tv box not powering on.
                        So, At the moment updating the Beelink GT1 is not recommended.
                        Hence don't update until all the problems are solved. Please follow this thread for further future information.
                        Please stay with the factory default firmware, until a new update solves existing problems.
                          No problems whatsoever here with the newer firmware.
                          Installed the OTA last week and have been enjoying root access ever since.
                            Where to find IMG factory SW file?
                            Free 100Gb space for your files:
                            https://degoo.com/g/Ov7nAz0
                              Beelink GT1 firmware download:
                              https://mega.nz/#F!bIVGFaKY!Om3XTxlHmjPB4x2_jukFYw
                              The Video Tutorial please refer to:
                              https://youtu.be/R59M1cz_trE
                                Anyone Know how to get it to power on if holding reset doesnt work
                                Nvidia Sheild Tv
                                ADT-1 Developer Kit
                                Wetek Core
                                Fire Tv2
                                Beelink GT1
                                Raspberry Pi2
                                Odroid C2
                                Nexbox A5
