Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
    UPDATE:
    Just received the OTA update - GT1_104M0. First impressions:
    1. The device is now rooted
    2. The annoying green flickering seems to be fixed. Need to test it further to confirm.
    3. The video brightness is now fine.
    ISSUES:
    1. DTS sound - failed to play with passthrough enabled both SPDIF and HDMI in Kodi/SPMC.
    2. HD Audio on all sound formats still not available. Must note that all sound formats work fine with the integrated MoviePlayer !!!
    3. HEVC encoded videos - 10bits / 1080p - still broken image with green parts all over.
    Will examine further and post results if interested.
    There is no sp00n ...
      please post your observations & also some pics!
        Did you tested DTS sound via MX player?
        Better result in Antutu video test?
        Free 100Gb space for your files:
        https://degoo.com/g/Ov7nAz0
          plasma MX Player doesnt play DTS as well - tried HW+, HW, Soft - No go!
          jaivelu I might test the wifi speed and see the driver version. I usually dont game so probably will not make any test on FPS etc. Will run the antutu tests though.
          Btw I just saw the admin on beelink forum post regarding the new update:
          QUOTED:
          Hello all, the new firmware is released now, you can try to update through OTA. This version main fix:
          open the root.
          fix the device can't write USB/SD/U disk.
          fix some city can't remain.
          fix KODI play some video appear Mosaic
          KODI resolution change to auto set.
          Thanks for all concern, for more solution, please waiting for the next version.
            Originally posted by sp00n View Post
            UPDATE:
            ISSUES:
            Beelink mention before no bug fix in this release hence no fix for green flickering and video brightness. My side after update still same no improvement.
              UPDATE:
              ISSUES:
              How can i updte,because i didnt receive somthing!!
              can you tell me the way?
                Settings --> About MediaBox --> System Update
                MXQ / M8S+ / MXIII-Plus / Mini MX / Mini MXIII / T95 / Mini M8S II / R68 / V88 / GT1
                  Ok thank you,i am trying niw
                    Pls keep in mind some users at 4PDA forum reported system hang after OTA update. Might be just a random case but anyway be warned.
                    I can confirm that for the last 3 hours I didnt notice the green flickering issue with this box. Mine is connected directly to AV receiver, so dont know if that might be a reason not to observe the above mentioned problem.
                    Antutu gets only 38k - 3D 9153, UX 12877, CPU 13000, RAM 3330 - seems to me the chip is not utilized very well in software. Rather disappointing but might get better with the time.
                    Some guys reporting HEVC videos being played correctly , but not my case. Might try another differently encoded and see if any difference.
                    I upload my DMESG info, might be of some use for devs.
                    In the meantime - expect no other update till mid of October. Ze Chinese are celebrating till 10th.
                      With the new update,kodi is still dark enough or it is my idea?
                      Sent from my iPad using Tapatalk Pro
                        After update KODI is still dark. My rk3368 plays the same movie on the same tv fine.
                          Also i ve noticed that if you see something in one addon and stop to go to other addon then kodi closed?
                          Has anyone have the same issue?
                            New OTA hangs, anytime I try. Is there a usb update file?
                              This update wasn't meant to fix dark and green flickering yet. Need to wait next update
                                Any idea how to find this?
