Also - my current box has an outer wifi antenna, and it has pretty good reception, would you say an inner antenna as the one of the gt1 would be at least as good? And last - does any of you know tronsmart s95 meta? Which would you say is better and more reliable?
Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Guys, i am new here, interested in the gt1, mainly for kodi streaming, web browsing and youtube. I am currently using a no-brand box, which has a lot of reliability issues - optical sound mumbling, green-pink picture, freezes, etc. Would you recomend the gt1 to be reliable and issues free?
Originally posted by BenarimoGuys, i am new here, interested in the gt1, mainly for kodi streaming, web browsing and youtube. I am currently using a no-brand box, which has a lot of reliability issues - optical sound mumbling, green-pink picture, freezes, etc. Would you recomend the gt1 to be reliable and issues free?
You can go with the Beelink M18 that has an external antenna, and there is an custom firmware for it(finless).
I am happy with the M18....
The gt1 has a lot of potential....but you'll have to wait(a lot).
My 2 cents.....go for the M18(it costs 54 dollars)
Sent from my MX4 using Tapatalk
Originally posted by Catadarius View Post
It is too early to buy an GT1.....it's full of bugs, it freeze often, has poor wifi range.
Hola, guys !
Just tried the new firmware 105M0, released earlier today.
1) To my surprise they managed to get DTS working properly - not in Kodi though, but in SPMC - with IEC passtrough device selected. DTS and DD audio plays just fine, but no joy for HD-audio yet
2) All my 10 bit HEVC videos seems to play fine without any visible artifacts.
3 )Other thing which now works is the frame rate switiching
4) the green flickering is also fixed.
Now the cons:
1) with my previous firmware the temperature was between 45 and 50'. Now its quite high - 65-70'. Not sure if this should be primary concern but nevertheless - keep in mind the device gets hot.
2) poweroff not working - obviously a new bug
3) the videos appear a little dark , tried to play a 4k to brighten the image but now it doesnt seem to work
4) video hardware acceleration not available
They also put some new options in the settings menu and removed the reboot option in about-section.
Continuing testing.
There is no sp00n ...
Now the cons:
Continuing testing.
Does switching of works for you? Many are complaining that only restart and sleep is working. Can you confirm?
​​​​​​â
Originally posted by Don_Pachuco View PostWhat are the main/most important areas to apply the thermal paste to, and any pics possibly of the locations of them? I would think Arctic Silver would be good enough?
I should add, on another note, that I have no issues with pass through and upscaling of audio to play through my Yamaha AVR in my home theater setup.
Further observations:
When using SPMC with amcodec - enabled - the framerate switching does work, but SPMC often crashes after a while. Disbaling this option keeps the program stable, but framerate switching is gone.
tenoce
PowerOFF doesnt work as already mentioned
Originally posted by tenoce View PostCannot update. I've already hard reseted my device, but when trying to update it says, "your system is damaged, wireless update is disabled"
I tried factory reset and then repeat the update process. Same result.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
tenoce
There are currently 5197 users online. 3 members and 5194 guests.
