Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Anyone know how to switch the kodi icon on home screen to open SPMC I installed. Is there a file I can edit to switch the patch from kodi to spmc. I wanna try and keep the kodi icon thats on there now.
Also anyone rooted this yet or have the factory Img?Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
I tell you wot. I did not notice till yesterday. I have my beelink gt1 connected to my 1080p projector, & i have noticed that while in kodi, it seems very dark. Its the same with my Acmax box as well. Is it like that on the s905 box as well. I have tried the newer version of S.B.M.C & the pic is grate but it keeps crashing all the time. Any suggestions any one. Thanks.
1. take power adapter off.
2.press pin hole upside down of the box.
3.turn on power adapter and keep pressing the pin hole at the same time.
4.keep pressing pin hole after you see recovery menu on the screen.
5.After you see it ,take remote and go for factory reset option.
After thet you will make factory data reset by hard way.
Box will rebot and you must to wait for entering desktop mode.
Now you will have all new sw ,like from factory ,and go again for Ota update menu and it will work.
Originally posted by bigall123 View PostI tell you wot. I did not notice till yesterday. I have my beelink gt1 connected to my 1080p projector, & i have noticed that while in kodi, it seems very dark. Its the same with my Acmax box as well. Is it like that on the s905 box as well. I have tried the newer version of S.B.M.C & the pic is grate but it keeps crashing all the time. Any suggestions any one. Thanks.Nvidia Sheild Tv
ADT-1 Developer Kit
Wetek Core
Fire Tv2
Beelink GT1
Raspberry Pi2
Odroid C2
Nexbox A5
There are currently 3195 users online. 0 members and 3195 guests.
