Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Originally posted by jaivelu View PostMXQ / M8S+ / MXIII-Plus / Mini MX / Mini MXIII / T95 / Mini M8S II / R68 / V88 / GT1
Originally posted by Jon7sky View Post
My M8S+ and Tronsmart MXIII Plus, both with the S812 chip, handle Dolby Digital passthrough over HDMI very well. But all my S905 and S905X boxes have the periodic dropout problem.
Originally posted by alwaysbless View PostHere is my video review guys covers Video performance, Gaming, Benchmarks etc.. cheers!
Yesterday itself I have watched your review video and even commented there!
Thanks once again for the review!!
Hi Gadget Friendly! I don't know you're in Freaktab Forum!
Can we have Libreelec for S912 based Boxes now pls ? now we have enough TV Boxes with S912 Chipset und many have received it and even more enthusiasists are waiting eagerly for their new Boxes...
it is not a bad idea to expect now a custom version of Libreelec / Openelec release. What do you guys think ? is it too early to ask for a Libreelec image for S912 ?
Hello.
I would advise anyone that these boxing is better?
Beelink M18 (the one I had, I liked it, the first off - then just glowed red LED and doing nothing more)
Beelink R68
Beelink i68 (difference compared to R68, probably only an external antenna?)
And this Beelink GT1
Mainly according to performance and quality software. So that all of Google Play.
Thank you very much.
Geekbench 4 Score for those interested > http://browser.geekbench.com/v4/cpu/196978
Geekbench 4 Compute Scores > http://browser.geekbench.com/v4/compute/43522
Originally posted by Catadarius View PostI have an gt1 box.
I've installed zenui launcher and now my box is stucked on the beelink logo....any idea on what to do?
Sent from my MX4 using Tapatalk
Mine arrived yesterday. Yesterday I spend almost 5 hours playing with it and when rebooting, for two times I got the same problem than you.
In my case, just cutting and restoring power solved the issue, as the next boot went normally.
As for the box, I just have one concern: Temperature.
Ive played games for almost 1 hour. After playing Riptide for 30 min, the CPU reported 83ÂșC (in the Kodi settings information -> Hardware).
Well i have just received my Bee link GT1 today, & it toteally rocks apart from 1 thing. The wifi sucks. I have a net-gear knight Hawk with 4 antenna, I getting just 8MB download & 14mobs upload. The box is in my bedroom . The router is just below my bedroom. I have opened up the box & there is 2 gold prongs in the corner of the circuit board witch touch 2 little connectors on the Bach plate, The plate were the 2 connectors are on are tiny. It really dose not seem to be large anuf for the antenna to be of any good. As for the paste thay have put on the heat shield is farcical to be honest. Thay have a metal plate stuck on the inside of the base plate were the heat is supposed dissipate but its not even touching the plate with the paste. It looks like another mod with some thermal paste & thermal pads. As for the wifi, I hope its a software problem & not a hardware 1. Update. I have sorted the wifi out. The 2 gold pins were not touching the contacts properly, so stuck a tiny bit of folded paper underneath. It works good now. As for the heat issue. I have put some proper thermal paste on the heat shield un till i get my 1" by 5mm high heat sink for it. Il keep you posted. Thanks.Last edited by bigall123; 07 September 2016, 16:23.
There are currently 1443 users online. 0 members and 1443 guests.
