Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
eOriginally posted by mo123 View PostWhy is there always 250MB RAM missing on S912 devices?
Is it used by the GPU/VPU?
Code:if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi
Originally posted by bigall123 View PostI have opened up the box...
...I have put some proper thermal paste on the heat shield until i get my 1" by 5mm high heat sink for it. I'll keep you posted.
How easy was to open this Box? Can you give some instructions?
corduroy27
I used plastic pic that i used to repair my ipad screen with. Prised the bottom plate. I have just put a 64gb samsung sd card in the beelink gt1 & it formats it for internal storage but the box just will not accept it for some reason.
Originally posted by bigall123 View Postcorduroy27
I used plastic pic that i used to repair my ipad screen with. Prised the bottom plate. I have just put a 64gb samsung sd card in the beelink gt1 & it formats it for internal storage but the box just will not accept it for some reason.**SkystreamX4 (S802)....M8S (S812)....Mini M8S (S905)....Nexbox A95x (S905x)
Originally posted by Zemitras View Post
Could you show some pics please?
I used plastic pic that i used to repair my ipad screen with. Prised the bottom plate. I have just put a 64gb samsung sd card in the beelink gt1 & it formats it for internal storage but the box just will not accept it for some reason.Originally posted by bigall123 View PostI just got it working. When you put the 64GB card in. Make sure you don't have a USB stick plugged in, Because it wont work. You have to format it first on PC first to fat32. But ts working grate now.Originally posted by ASW1 View PostWatch this from 3:45 https://www.youtube.com/watch?v=5apvYVXdLeE
bigall123, if you finally add a Heat Sink on it, please take a photo with it, before you close the Box... Because I don't see space for something like this.
It's great to see that supports 64GB microSD in practise! And maybe 128GB too...!!!
In order to put a heat sink in the beelink gt1. You will have to remove the metal plate on the under side of the box. The reason being is, I'm putting a 1" by 5 mm heat sink in place of the metal plate because I don't think the heat shield that covers the CPU, is touching the plate on the bottom. PS. I'm even thinking of drilling a couple of holes on the bottom & putting bigger feet on it for air to get in.
There are currently 3192 users online. 0 members and 3192 guests.
