Beelink GT1 TV Box Octa Core Amlogic S912 ~2/16GB
Originally posted by Ormbett View Post
Ships between Aug 31 - Sep 6 (according GB)
I just checked it and it's already delayed with another day from september 1 - september 7. They always seems to put release dates and they never seems to make it work. Always delays.I bought one because i thought it would be shipped in august, but i should have known better.
GT1 S912 also running at 1.5Ghz instead of 2.0 Ghz as on S905X?
So only difference between cheaper tv boxes is the Mali T820 GPU and nothing else?
When I compared the performance Amlogic S905 and Rockchip RK3368 processors last year, I noticed Amlogic S905 single thread performance not being much
I hope all manufacturers will fix the marketing of S905 & S912 tv boxes since Amlogic's speed cheating has been identified.
Originally posted by blackadder View Post
Thanks for sharing the video! It looks really nice! I saw in the video that one core ran at 2Ghz. So the 912 can run at 2Ghz after all?
Max is 1.5Ghz even if benchmark tools show 2Ghz.
There is no difference in speed when run at 1.5, 1.75 or 2Ghz, they all get the same performance.
It was a marketing trick by Amlogic.
Here is more information
It looks like Odroid did manage to get real 1.75Ghz with heavy overclocking, extra cooling and different software.
But 2Ghz is a no-go.
Originally posted by kiziumiziu1981 View PostVideo review of Beelink GT1
Its good to know the capabilities of the Beelink GT1.
Other than the 1.5Ghz bottleneck, whether this device capable of supports & plays various video codecs including the 4K?
How is the WiFi performance of this Beelink? (previous beelink devices have low wifi signal problems)
Yesterday i have received GT1 from Bee-link factory via DHL.
Device is a very small ,with quality plastic.
Premium design stands out from other devices from China.Thet is understandable, given that the bee-link is a brand name product.
The lower part of the device is from rubberized plastic.Due to the small size of the box it was left for AV output and a third usb.It is question about the cooling due to the very small dimensions.
The AC adapter is the smallest I've ever seen, you can swallow it.
Unfortunately AnTuTu shows that the clock is at "1.5 GHz", because of only modest almost 38000 AnTuTu points.With this results there is no Amlogic 2.0 Ghz statements,but there is no mention on the gift box thet Cpu is clocked on 2.0 Ghz,Bee-link is protected from 2.0 Ghz false Amlogic marketing.
-There is no Chinese app junk, just the basics and of course Kodi 16.1 with inserted addons.There is Kodi mate app with mate addons for additional insertion addons by categories for those who have poor knowledge of the Kodi.
-Drm info: only third level.
-Youtube is limited to 1080p.
-To compliment is the top notification bar and the bottom antique one,that gives all the options of adjusting the volume, forward, back, home and so on to the closure and re-start.
-UI is fast, everything goes quickly and smoothly.
-System is stable for now.
-Antutu Video tester gives 865 points, 27 fully supported, partially supported only 3, and no one not supported.
-3D Mark Sling Shot ES 3.0 .... 573 points
-3D Mark Unlimited..10118 points for Ice Storm.
-3D Mark Ice Storm Extreme ... 6162 points.
-A1 bench SD for Internal memory: read 54,83MB / s Write-27.74MB / s.
-Velamo Multicore 1477.
-Velamo Browser 2615.
-Velamo Metal 860.
-GeekBench 3 ,single core 647,,,,,,Multi Core ...2764.
-GFX Bench:
Car chase Es 3.1 1920x1080 ............................................149.6 frames(2,5fps)
1080p es 3.1 1920x1080 car chase offscreen....................149.6frames(2.5 fps)
1440p manhattan 3.1.1 offscreen 2650x1440.....................159.0 frames(2.6 fps)
Manhattan 3.1 es 3.1 1920x1080......................................... 295.0 frames(4.8 fps)
1080p manhattan 3.1 offscreen 1920x1080,,,,,,,,,,,,,,,,,,,,,,,,296.7 frames(4.8 fps)
Manhattan es 3.0 1920x1080,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,445.7 frames(7.2fps)
1080p manhatan es 3.0 1920x1080....................................453,3 frames(7.3 fps)
T-REX es 2.0 1920x1080......................................... ...........949.5 frames(17 fps)
1080p T-rex offscreen ws 2.0 1920x1080...........................1.044 frames(19fps)
Render quality es 2.0 1920x1080......................................... ..3.307 mb PSNR
Render quality High precision es 2.0 1920x1080....................4.028 mb PSNR
-Quadrant standard not passed !!
-Wi-Fi test speed of 50 Mb from VDSL net, gives 41 Mb, and the router is on 40 cm distance from the device.I have it some Chinese boxes at the same distance with worse results.
-Restart takes 48 seconds.
-Device is locked, no root access.
-The picture quality is good.
-Android 6.0.1, version is from 19.08.2016.
-There is OTA,but say it is on the latest SW.
-There is no problem with Cpu Temp.
It was all for the late night testing,more to come.
Beelink GT1
One of the Most Interesting ways I have seen WiFi Antenna set up in a media player Pogo Pins
A few more happy snaps of around the Beelink GT1
Ports
Under Box
Under PCB not much here
RAM
CPU
WIFI Chip AW-CM273SM Haihua module agent completely replace Ap6335
The AW-CM273SM IEEE 802.11 a / b / g / n / ac SDIO Wi-Fi with Bluetooth 4.1 combo stamp module is a highly integrated wireless local area network (WLAN) solution to let users enjoy the digital content through the latest wireless technology without using the extra cables and cords. It combines with Bluetooth 4.1 and provides a complete 2.4GHz Bluetooth system which is fully compliant to Bluetooth 4.1 and v2.1 that supports EDR of 2Mbps and 3Mbps for data and audio communications. It enables a high performance, cost effective, low power, compact solution that easily fits onto the SDIO and UART stamp module.
PHYceivers 10/100/1000M Gigabit Ethernet
Now for a few Benchmarks
DRM info
Passmark
Geekbench
Full detail here >https://browser.primatelabs.com/geekbench3/8001386
UI populated a little
Shut down options
Stress test
Vellamo
AI SD Bench
3DMark
Worktest and Memory
CPU-Z
So all in all much the same as others that have been tested, Heat is not a problem keeps cool
WiFi is OK will do some further testing ethernet is ok
Originally posted by plasma View PostYesterday i have received GT1 from Bee-link factory via DHL.
-Velamo Metal 860.
-GFX Bench:
There are currently 2256 users online. 4 members and 2252 guests.
