http://www.freaktab.com/showthread.p...ersportROM-v10
Notes
- Flashing will delete everything on your Cube consider backing up first and remove any sdcard
- Download and extract to a folder
- connect the tab to the PC (you did remove the sdcard)
- start the ROM flash tool
- put the tab into flash mode, the PC should detect it, see below for instructions
- install drivers if required
- erase idb
- flash, the ROM kit is correctly configured
- the tab should boot to recovery and format cache, data and sdcard (this will take a few minutes)
- the tab should now boot
So what do you get?
- defaults to english uk
- root with Koush's Superuser
- some bloat removed
- busybox and init.d support
- play/market fixes for more apps in Google Play
- a choice of 2,4,6 and 8 gig app space, 2 is the default but the others can be selected from the flash tool
- Power off the Cube
- hold Vol + and connect to usb
- After 3 to 4 seconds release Vol +
- The Cube should be detected by the PC.
- If you have not already installed the drivers now would be a good time. I've included the drivers in the ROM kit in the RockusbDriver folder.
