Cube U30GT 2 4.2.2 v2.04 Test 900supersportROM v10
Originally posted by rrileypm View PostLook in the ROM folder of the flash kit.
There are multiple parameter files. The default is 2gb. Rename it parameter2gb. Then choose the size you want to use and rename it parameter. Then start the flash tool and erase IDB...and flash.
That's it.
Sent from my GT-I9300
Worked like a charm!!! My goddaughter is currently downloading & playing Kids Animal Piano on it- I think it's a keeper. Thanks a lot =D
Wifi disconnect during sleep
Has anyone figured out how to keep the wifi alive when the tablet goes into sleep mode after a few minutes of inactivity? I've checked the settings under wifi and have selected to Always keep it awake but of course that doesn't work. And Regpon as well as other wifi keep alive apps from the Play store do no good either.
I don't guess it's really that big of a deal... but I noticed that when I go to use the tablet after it's fallen asleep that it's laggy. I believe it's because the wifi hibernates then when it wakes it updates all the background data and slows the tablet down.
One thing I do is go to developer settings and check the option to keep on while charging. That way my downloads will continue
It is a work around...not necessarily a fix.
RandyRandy
Guest
Use the app regpon WiFi keep alive from the playstore....problem solved
Sent from my U30GT 2 using Tapatalk HD
Just back from holidays. That's a good d way to start :-)900Supersport
freaktab developer
Official V2.04 is out with multi-window function !
Translation by Google
Quad peas 2 V2.04 firmware released the official version: http://bbs.51cube.com/thread-77406-1-1.html Major updates are as follows:
1 An increase HD / puqing double resolution display mode
2, increasing the multi-window function, take advantage of quad-core ultra-high-definition screen peas 2
3, increasing state native HDMI output loud speaker mute function
4, optimize button boot time
5, increasing the external storage device identification multi-partition
6, the optimal audio driver, the audio output is more stable
7, the depth of speed, the system run more smoothly
Should have a new ROM available tomorrow based on the latest cube firmware.900Supersport
freaktab developer
Will be the ROM I´m going to sell that thing flashed with. I´m through with it. With all that chinese stuff.
It is a fast tablet...no discussion there...but Wifi kills it for almost everything I want to do.
Just bought a Asus ME301T until the Sony XperiaZ tab comes back from repair (No Bluetooth and NFC!!!)
The Wifi of the Asus reaches 15meters more!!! NO JOKE! And that is with antenna mod! two toshiba Wifi antennas are connected. Hell I could go over to our neighbours and still have a stable Wifi connection.
So I just can advise anyone having problems with the wifi...don´t mod the antenna or anything...go and sell that damn thing. Alltogether I´ve spent about 300€ and still have a almost unusuable device.
So thank you Brian for all your work ´cause soon I won´t come here anymore.
New ROM posted.900Supersport
freaktab developer
There are currently 2029 users online. 1 members and 2028 guests.
