[ROM]MXQ 4k 1GB/8GB (rk3229) Android 5.1 Superceleron v1.0
I tried the latest stock rom for the mxq 4k and this one...I was previously on kitkat....in both cases I lost sound but everything else appears to be working. I was previously using sound from hdmi to the tv...I've tried the various options under sound manager...I've told it the output is to a tv....any suggestions on how to get it back short of "go back to kitkat"?
Originally posted by famewolf View PostI tried the latest stock rom for the mxq 4k and this one...I was previously on kitkat....in both cases I lost sound but everything else appears to be working. I was previously using sound from hdmi to the tv...I've tried the various options under sound manager...I've told it the output is to a tv....any suggestions on how to get it back short of "go back to kitkat"?
To the one that downloaded build-6 of ftmc plz update to build 7 since i found a bug on it....
Originally posted by diephoenix View PostI upgraded to this Rom, working 100%, but the box powers off randomly. Anybody else getting this?
me too, but it makes me also with other firmware , but not all ? I just notice it
I check if overheating but no it remains at 80 ° Celcus and therefore message " to stop" random
my guess is that it's a third party app with a memory leak ?Last edited by professeur83; 16 August 2016, 16:17.
I checked the logs, and it seems the power off is caused by lowmemory. I updated FTMC to latest, reset FCMC back to first install, installed app Greenify that allows apps to be forced to hibernate in the background and applied the hibernate to all the apps except FTMC, including system apps. FTMC is a lot more responsive and the box looks stable. Will monitor it and see how it runs.
Originally posted by diephoenix View PostI checked the logs, and it seems the power off is caused by lowmemory. I updated FTMC to latest, reset FCMC back to first install, installed app Greenify that allows apps to be forced to hibernate in the background and applied the hibernate to all the apps except FTMC, including system apps. FTMC is a lot more responsive and the box looks stable. Will monitor it and see how it runs.
thank you to all
Originally posted by diephoenix View PostSo far it is running perfect, no more power offs.
superceleron your opinion - Which media box do you think is the best for just using kodi? And which chip is the best?
There are currently 2990 users online. 0 members and 2990 guests.
