Did you get a chance to look at it? Is there any way to enable widevine on this ROM?
[ROM]MXQ 4k 1GB/8GB (rk3229) Android 5.1 Superceleron v1.0
After some playing and researching, I've found that the MXQ-4K problem is related to CPU (over)heating. Could be also related to RAM, but I'm still not sure. I installed a strong external ventilator
pointed to open circuit board and there were no problems with either robooting not out of sync issues. As there will take some time beofre I'll get the ordered good heatsinks, still not sure.
BTW, where can I find the latest FTMC builds?
yes this box have a lot of heating problems, normal for the price of it!
Ftmc latest build in this post : http://freaktab.com/forum/tv-player-...669#post598669
Hello, I was hoping someone could help me. I am trying to update the device. However, when I press the button in the back (AV port) and then power, I see the Dead Android guy with a Red Triangle. Is there any way to get past that? I would appreciate any help. The box works fine otherwise with its current Android 4.4 build. I am just trying to update it to 5.1
Originally posted by canbonbon View PostHello, I was hoping someone could help me. I am trying to update the device. However, when I press the button in the back (AV port) and then power, I see the Dead Android guy with a Red Triangle. Is there any way to get past that? I would appreciate any help. The box works fine otherwise with its current Android 4.4 build. I am just trying to update it to 5.1
Also, you need to put an USB cable on USB 4 (rear on device) connected to your PC. If you know what I am talking about this might help. Otherwise, please read how to flash a new firmware on RK3229
systems.
Originally posted by tomsag View PostJust installed new heatsink and the reported temperature still rises to 96 (but it's within up to 125C as reported by Rockchip). Some reboots happened. This is still a firmware problem, as I see now.
How can I force a new ROM install from SD card as on SuperCeleron?
There are currently 2122 users online. 0 members and 2122 guests.
