My personal experience is it either shows degrees or (in case of a non compatible firmware) nothing, just a ? sign.
[ROM]MXQ 4k 1GB/8GB (rk3229) Android 5.1 Superceleron v1.0
Not sure about the Kodi hardware info, is correct or not.
Linked app works on Amlogic but doesn`t find cpu temp sensor on RockChip devices.
https://play.google.com/store/apps/d...utemp&hl=en_GB
Updated my MXQ 4K box with this image. Works great. Also installed latest version for FMTC. The only major issue is occasional power shutdowns. Not sure why. Installed cooler Master app. Will monitor for a week and see if that makes any difference. This device never used to shutdown with the original img, so clearly this is something that surperceleron img introduced. I am also surprised that only a few people are seeing it.
Hello, I downloaded this rom for my box and I buy 1 bluetooth usb 4.0 but it don't work, I search from google and see it will work on cyanogedmod rom. Can you mod the rom so it works with bluetooth usb Thanks.
Sorry my English ability is not good. I use google to help and google probably not much preparation
Originally posted by ngochoa318 View PostHello, I downloaded this rom for my box and I buy 1 bluetooth usb 4.0 but it don't work, I search from google and see it will work on cyanogedmod rom. Can you mod the rom so it works with bluetooth usb Thanks.
Hi SuperCeleron,
I bought an OTT TV Box MXQ 4K (Made in China) and I would like to know if this firmware will work on my device. The device has Android 5.1.1 (Lollipop) and terminates applications that are placed in the background, not allowing a VPN application to run in the background. Does this firmware allow applications to run in the background?
Thanks,
CYK_BR
Thanks,
CYK_BR
Nós temos a mesma box com o mesmo firmware e os mesmos defeitos. Eu achava que era algo do laucher da box que forçava o fechamento, mas não é ele.
Ainda não tentei atualizar o firmware, mas se continuar desse jeito, terei que testar...
Originally posted by Zeka View Post
CYK_BR, você conseguiu resolver esse problema das aplicações fechando quando vão para background?
superceleron Would you happen to advise on the FW for the MX4N-V02 board? my MXQ Pro 4K housing happened to come with this one, the NAND chip is an ESSENCORE and WiFi SV6051P.... I have tried a lot of downloadable FW compatible with the RK322A/RK3229 chip but I have not been able to go beyond the recovery mode which by the way it does not have the option to be able to upgrade via external device (SD) , I need to start all over, this board had Lollipop 5.1.1 and Kodi 16.1 which I managed to upgrade eventually to Kodi 17.1 however after some time , one fine day it was stuck in the Android Logo ... appreciate any pointers you can share. Thank you
I just fixed the youtube 240p problem unistalling youtube 'recent updates' from the settings and installing previus youtube build apk, not the lasted 2017 , just an apk from 2016 and now i can watch videos in 720, same for netflix, unistalled and installed the most recent apk but not the lasted
Originally posted by superceleron View Postwell look like i cant fix widevine on this one by my "normal" way, without the sdk... looks like they did a bunch of poo... on this one! sorry!
It's working like a charm
Originally posted by superceleron View PostYes i know! i simple i still dint see any gain of L3.
But is nice to see that some ppl still use this!
Molotov
free french TV channels.
must pay for more channels and to record channels.
MyCanal
paid satelitte channels where you need an account.
Thanks a lot for your work, i'm a geek of TV Box (around 20 android boxes, Apple TV 2 & 4, all models of raspberry pi, ...)
Originally posted by manu_manu4 View Post
For your info, i leave in France and we use 2 apks to watch french TV channels, who need DRM L3 and french ip address (i use vpn when i'm out of France)
Molotov
MyCanal
But is good to know
There are currently 2265 users online. 0 members and 2265 guests.
