NEXBOX A95X Amlogic 905X FIRMWARE UPDATE 20160824
Originally posted by tenoce View Post
So, what can someone do if he has the older model without the button, to get into recovery mode?
Originally posted by marinero57 View Post
thank you john for your answer ; but i have not this button :
*USB Burn Tool v2.0.8
1. Ensure A95X is powered down and not plugged into anything (i.e. hdmi, no sd card in slot, no power cable, etc.)
2. USB cable plugged into PC
3. Start USB Burn tool and load image that you are going to burn. Make sure image is "verified" by the tool.
4. Press Start on USB Burn Tool
5. Insert USB cable into the USB port farthest from the sd card slot. (i.e. closest to the "back" of the box)
6. Watch USB burn tool or listen for windows sound tone. You will see USB burn tool show connected and start flashing.
7. Once USB burn tool has completed successful burn, stop tool and unplug usb from box.
8. Should be good to go.
**SkystreamX4 (S802)....M8S (S812)....Mini M8S (S905)....Nexbox A95x (S905x)
Originally posted by ladyjack View Post
Marinero57.....I had the same issues with my A95X 2gb/16gb box.....No reset button. After several iterations of trying to get USB burning tool to work, the following is what finally worked for me. Can't tell you why thought, it's all a mystery.
Originally posted by marinero57 View Postyou're a god ladyjack !!! i had already tried this method, but i pushed the start button AFTER having plugged the box ; update OK .....thank you very much
Ladyjack thank you!!!! However even the update has not solved my issue with the HDMI. Still no HDMI signal on my Panasonic PV60, only A/V.
Yes same name just missed the x... I working on the nexbox x95 905.... Jacked wrong thread... The A5 is that one if the 905x models if i remember correctly they name each 1 gig 2 gig as different model?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostYes same name just missed the x... I working on the nexbox x95 905.... Jacked wrong thread... The A5 is that one if the 905x models if i remember correctly they name each 1 gig 2 gig as different model?
There are currently 8510 users online. 4 members and 8506 guests.
