NEXBOX A95X Amlogic 905X FIRMWARE UPDATE 20160824
Sony PS3 Dualshock Controllers use non-standard Bluetooth drivers
You will need Sixaxis Controller App and ROOT ACCESS to use a PS3 Dualshock via Bluetooth
If you have ROOT, and wanna check, download Sixaxis Compatibility Checker
If all good, then i highly recommend a purchase of the app for a few bucks and using a "good quality controller" like the PS3 Dualshock
Originally posted by JoeySmyth View PostSony PS3 Dualshock Controllers use non-standard Bluetooth drivers
Originally posted by gungrave80 View PostWith the last versione of Sixaxis Controller, PS3 joypad is recognized. I bought also a bluetooth controller from Gearbest (Terios T3) and it works as well
I added all the apps I use in the system/pre app and flashed all worked fine except now AdAway says not enough space on system partition for host file and su binary update fails. If I remove a couple apps from pre app su binary and AdAway work. Is there another way to get all my apps preinstalled without filling up system partition. Also curious about visibility for navbar and status bar.
If anyone has a copy of their ROM with navbar and status bar enable please send me a link to itLast edited by romula; 27 September 2016, 14:48.
Hello everybody, i have just bought the nexbox a95x and i'm missing very much navbar, notification bar and recent apps.
using some apps i have at least some of these features (but not complete)
i was reading all the thread... but (being not so expert) i have not understood if i can modify the img file to have root, navbar, notifications and recent apps
is it possible? how should i do?
thanks to all
Well if you have eachlink IX809 Pro or coowell v5 they are s905x 1gb 8gb nand, this firmware to a95x will work fine, wifi too.
board dx-809 x10-s905x_v1.1
http://www.mediafire.com/download/jt...5_USB%26SD.rar
to root just install super su work very well
I suggest uninstall facebook, and others unnecessary aplications, to watch movies and etc, will
work more faster.....
Thank you
trebor
ModeratorLast edited by herr_marechal; 28 January 2017, 05:59.
There are currently 3377 users online. 0 members and 3377 guests.
