What type of android box?
Ohh sorry I was in the right thread. http://freaktab.com/forum/tv-player-...m-kii-lollipopPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I'd go for an S905 dual booting Android/LibreElec. I wouldn't class any Rockchip/Amlogic beefy, I also wouldn't use Android Kodi. LibreElec on the S905 is considerably quicker then any Pi and has more codec/resolution support.
Nothing touches the Shield, although we will get to a point where boxes will have better CPU performance it will be a very long time before they get anywhere near that GPU. It also has the best Android Kodi support if you didn't want to use Open/LibreElec and is a vastly better Android machine then any Rockchip/Amlogic.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by ididmytime View PostI'd go for an S905 dual booting Android/LibreElec. I wouldn't class any Rockchip/Amlogic beefy, I also wouldn't use Android Kodi. LibreElec on the S905 is considerably quicker then any Pi and has more codec/resolution support.
Originally posted by bluesmanuk View PostNo Kodi isn't going to drop Android support any time soon.
They are dropping specific support for AMLogic though from 17.
Even if they drop it, then what the AMLogic android box users will do? Whether they'll shift to some other similar Kodi alternatives or Kodi based forks?
Originally posted by jaivelu View Post
What??? Why they are dropping support for AMLogic???!! because of the questionable addons?? or something more is there?
It doesn't mean that Kodi won't work with AML boxes but there is less of a guarantee that it may work as well across the board.
There is a fork called SPMC that talks of AML getting some love.
Time will tell.
There are currently 4366 users online. 1 members and 4365 guests.
