Note that this system uses a different multi-boot system. For use with the new system is multi-boot, the previous system images to SD cards (OE, LE) , you must add these to the SD card FAT partition, the file s805_autoscript (it can be downloaded at the same link).
LibreELEC for Tronsmart MIII Plus
Test image with LE 7.0.2.4. The system can be run from SD card or USB flash drive. To use you need to activate new universal multiboot. For use - download the image, burn to SD card to insert into a TV console, enable using the toothpicks. After a single activation of multi-boot using SD card, you can use a USB flash drive with the recorded image.
Note that this system uses a different multi-boot system. For use with the new system is multi-boot, the previous system images to SD cards (OE, LE) , you must add these to the SD card FAT partition, the file s805_autoscript (it can be downloaded at the same link).Tags: None
The updated image. A number of changes to the load scripts. Added reboot into Recovery. Note that when using the system with external SD card before selecting reboot into Recovery, you need to remove the script aml_autoscript SD card from FAT partition. Otherwise, when the script aml_autoscript and select reboot into Recovery, the looping start. If this happens, turn off TV box and remove the script. After that, you can continue to use this SD card.
i have intalled LE but from other source, it's in ZIP and the archive contains this
the updater-script
Code:show_progress(0.500000, 3); set_bootloader_env("upgrade_step", "3"); ui_print("Writing kernel image"); write_raw_image(package_extract_file("KERNEL"), "boot"); show_progress(0.020000, 0); ui_print("Wiping System"); format("ext4", "EMMC", "/dev/block/system", "0", "/system"); mount("ext4", "EMMC", "/dev/block/system", "/system"); ui_print("Writing system files"); package_extract_dir("system", "/system"); set_perm_recursive(0, 0, 0775, 0644, "/system"); set_perm(0, 0, 0755, "/system/SYSTEM"); unmount("/system"); set_bootloader_env("upgrade_step", "2"); show_progress(0.100000, 0); ui_print("Image Installed Successfully");
The honors option, which is installed in the eMMC from those that run from external media in the dtb file. When installed on the internal memory is used dtb from the internal memory, and when you start from external media is used assembled when assembling the external image from the source, that is). Therefore, for a proper use of external drives, need a working source file that needs to pull out of the console. By the way, the config of the kernel (which works in LE) can be obtained by the command cat /proc/config.gz>config.gz . That is, if the configuration options were awarded this opportunity.
Отличие варианта, который устанавливается в eMMC от тех, что запускаются с внешних носителей в dtb файле. При установке во внутреннюю память используется dtb из внутренней памяти, а при старте с внешнего носителя, используется собранный при сборке образа внешний (из тех исходников, что есть). Следовательно, для правильного использования с внешних носителей, нужен рабочий файл исходников, который надо вытаскивать из приставки. Кстати, конфиг ядра (которое работает в LE) можно получить по команде cat /proc/config.gz>config.gz . Это если в опциях конфигурации была отмечена эта возможность.
There are currently 1902 users online. 0 members and 1902 guests.
