LibreELEC for Tronsmart MIII Plus
Originally posted by t0rx309 View PostCan I dual boot from sd card without installing to nand?. I am running older version of Openelec this way at the moment.
to all
ver 17.4_20170830
Test variants of Libreelec KODI-18 (Leia) images for s812 s802.
Originally posted by balbes150 View PostTest variants of Libreelec KODI-18 (Leia) images for s812 s802.
https://forum.libreelec.tv/thread/15...2883#post92883
used 100 tar version = it boots ! WiFi working and LAN working ( dragonfly 1.5 = oke )
played some trailers...looks fine
will do more testing
added bugs:
kernel module failed : systemctrl loading module( red on boot )
--- solved:
YouTube add-on : search : best game trailers 2018.. on some vids error = invalid parameter
-youtube add-on got a update..few min ago.. re-testing = looks solved
----solved:
Some vids : loading circle , but vid runs underneath and kodi layer pause/play etc not there ( Noway to end vid)
-seems the xiaomi 3g router is causing this weird issue (same vid other wifi router works)
addon : rtmp dependencies missing *disabled
-solved rtmp addon , got a update
Cheers and thanks balbes150, keep up the goodworkLast edited by mitchell4you; 09 June 2018, 20:45.
There are currently 2168 users online. 0 members and 2168 guests.
