LibreELEC for Tronsmart MIII Plus
Originally posted by balbes150 View PostWhat model TV set-top box and the image LE ?
It was installed on a brand new box that I just opened I installed the correct version LibreELEC-S812.MXIII_Plus.arm-7.0.2.5-update . Like I said, all wilro's versions of OE and LE work perfect. There is something wrong with this version. They are Tronsmart MXIII Plus Android 5.1 2G/16G TV Box Amlogic S812 Quad Core 1000M Gigabit LAN HDMI BT4.0 2.4G/5G Wifi KODI OTG. Board inside says Netxeon M82G V2.1
Originally posted by dktn View PostI have M8s with stock firmware like this "n200C-user 4.4.2 KOT49H 20160229 test-keys". I would like to know how the way to install LE on SD card. (Dualboot).
It means I go to https://yadi.sk/d/S6KtL-SVuHcLq/SD_USB/20160907 then dowload LibreELEC-S812.MXIII_Plus.arm-7.0.2.5_20160907.img.xz file to my PC.
- use 7zip to unzip LibreELEC-S812.MXIII_Plus.arm-7.0.2.5_20160907.img.xz file became LibreELEC-S812.MXIII_Plus.arm-7.0.2.5_20160907.img
- Use win32diskimage chose LibreELEC-S812.MXIII_Plus.arm-7.0.2.5_20160907.img file then write to SD card
- Put this SD card to M8S while reset button push and the power on.
Do I need to do extra more?(sorry for my English)
I tried to make dualboot as i discribled but not work.
When i insert sd card and use sticktooth the icon appear 1 second then disappear for 4 seconds and nothing happen.
I release reset button on screen only icon and not disappear and nothing happen
I pull sd card out of M8s then it boot to android.
Please help me to make dual boot.
I download fileLibreELEC-S812.MXIII_Plus.arm-7.0.2.5_20160907.img.xz at path https://yadi.sk/d/S6KtL-SVuHcLq/SD_USB/20160907 then image to SD card. When boot and sticktooth appear screen blur( not boot)
- I replace file kernel.img and system by other I unzip then it boot from SD Card and has icon LE and has error "cant access E:system" and Stop.
I think M8S have read from SDcard but something file on SDcard not enough for it boot.
- I try use universe boot v0.6 update at androi but it say E: footer is wrong, E;: signature veryfication fail.
There are currently 2825 users online. 1 members and 2824 guests.
