Sunvell T95Z Plus TV Box Amlogic S912 Octa Core
    I I have the link but I just tried it from recovery with USB & says footer is wrong , signature verification failed? Do we need clockwork recovery or twrp?
      nexy33, the zip is in data/data/something
        Tried also from sdcard, didn't work. Dunno
          WAIT !
          After rebooting & already done a factory reset in recovery I did the OTA again & it failed then I tried it again and it WORKED ! So just keep trying the OTA i guess ( weird )
            I hit up date and left it 30 mins later I came back expecting a brick but it had done it last update to 6 went flawlessly
            Sent from my SM-G930F using Tapatalk
              Those looking for the update after downloading can locate it on your device before you update:
              Click update later:
              You can then locate update.zip in location (before you update) /data/data/com.adups.fota/files/adupsfota/update.zip.
              Search or browse for location I use ES File Explorer.
              Copy to sd to network as required, handy to keep in case things go belly up.
                Backup before you update !! 5 mins extra saves a lot of hassle down the line
                Sent from my MI PAD using Tapatalk
                  Can someone please tell me if you can use a VPN with this box? I have scoured the internet and find NOTHING about using a VPN with this box. I have seen reviews where there is a VPN on the settings but they skipped over it, didnt even mention it at all. Very strange?? I like the looks of the box and it seems like it would be good but I dont want to buy one and then not be able to use a VPN with it.
                    It has vpn settings. I use vpn unlimited which uses an app
                      Hello Boneo and thank you very much for the info. I don't suppose you have or know where I can get a "How To" for the VPN on this box do you? Now that I know it can, I am going to purchase one right now on Fleabay. Any help would be highly appreciated ;-)
                        I don't, Its just normal vpn settings for marshmallow.
                          No way to force RGB on HDMI output on this TV box?
                            Which current SPMC version is correct for my T95z. AArch 64 or Armeabi v7a.
                            Note only the Armeabi apk seems to allow installation.
                            I have attached screenshots of the SPMC download options and droid info for system.
                              I have the same android tv box but with the Greatever brand. My problem is when I changed the passcode, the box went into restricted mode, all of the apps disappeared. How do I get out of the restricted mode?
                                I have make custom cooling solution for my T95Z Plus. Before temperature when i watch movies on Kodi was 73 °C and now is 53 °C.
