NEXBOX A1 TV Box, Android 6, Amlogic S912 2/16GB BT 4.0 Dual WiFi
    ● Android 6.0:
    ● Amlogic S912 CPU
    ● 2G DDR3 RAM 16G eMMC:
    ● The dual band WiFi can implement multi-task at the same time.
    Gearbest
    A1 NEXBOX A1 TV Box, Android 6, Amlogic S912 2/16GB BT 4.0 Dual WiFi
    Arrived today thanks to Gearbest and DHL shipping very fast
    GPU: ARM Mali-T820MP3
    System: Android 6.0
    CPU: Amlogic S912
    Core: 2.0GHz,Octa Core
    RAM: 2GB, RAM Type: LPDDR3
    ROM: 16GB
    WIFI: 802.11 a/b/g/n Dual band, BT4.0
    Interface: AV,DC Power Port,HDMI,RJ45,SD Card Slot,USB2.0
    HDMI Version: .2
    Spec's of the Nexbox A1
    Whats in the Box
    Underside SKhynix ram
    Top Side a decent looking heatsink Glued on by the looks that will help, Wifi Chip AP6330 (heat sink on solid it can stay)
    A Thermal Pad between the heatsink and weight plate seen that before great idea, PCB type Wifi antenna
    Reset Button Behind AV Port
    Better than the sticky tape type of antenna I believe
    Vents Underneath That may help with circulation
    Full Side SD Card
    The remote looks ok
    More to happen :-)
      Comes rooted? non rooted?
        Yes we have root, not done too much yet with it
        Slowly it happens looks ok, thermal looks good
        No ethernet or setting to turn it on, someone forgot I guess
        Wifi OK...google works.....may be a goodie.
          Received this today, nothing on screen when plugged in, with multiple cables, on all inputs into working outlets. Remote doesn't do anything. What am I doing wrong?
            NO red or blue led on front of media player?
              Nope, nothing.
                Can you check there is power coming out of power pack @5vdc
                  How would I check that?
                    If you have a Multi Volt tester, maybe a friend has, or local electronic store may help.
                      Nexbox A1 2/16GB s912 Benchmark testing
                      Today we have the standard run of Benchmark testing to see how the Nexbox A1 performs.
                      Temperatures appear ok No melt downs, idle in the 40's under the pump 70's plus
                      Performance is looking ok as compared with other 912 tested so far
                      First the launcher looks ok, lots of screens to get to what you're looking for.
                      DRM Information
                      CPU-Z with the what's going on the inside:
                      Vellamo Benchmark
                      Geekbench 4 CPU: Full Detail > http://browser.geekbench.com/v4/cpu/382774
                      Geekbench 4 Computer: Full Detail > http://browser.geekbench.com/v4/compute/76318
                      Passmark Benchmarks scores
                      Memory Test
                      A1 SD Memory Test
                      3DMark Benchmark Scores
                      WiFi Connection Ok
                      AIDA64 results :
                        trebor, thank you for your great work. I want to know why, in all your reviews, you don't test hdmi audio (ac3 and dts) passthrough within kodi when the box is hooked to an a/v receive. I ask you that as audio passthrough is the main problem with amlogic s912. Cheers
                          Always the same problem and it's always there.
                          Not easy to get to the Amp to test I am afraid and you know deep down it does not work you're just hopping it will
                          Cheers
                            Thanks for your answer. I hope you'll let us know when a box tv with amlogic s912 will come out without this issue. Cheers
                              Thanks!
                              We have coupon for it.
                              coupon code: GBNA1
                              Price: 63.99
                              #1
                              Gearbest TV Box & Mini PC Page
                              #2 Flash Deals Flash Deals
                              #3Coupons Coupons, Coupons and More Coupons
