NEXBOX A1 TV Box, Android 6, Amlogic S912 2/16GB BT 4.0 Dual WiFi
Bought one of these, received yesterday, looks real good, the video output quality is superb, well worth the price.
I opened it up to dim the front light.
What I'd like to do to this one is install an IR extender jack so I can hide the unit yet still operate with the stock remote. I don't want to look at the darn thing. Yes I have a nice usb i28 lighted remote that costs almost as much as the unit itself. Great but I still want to add that jack and hide the unit.
LOOKS like I can simply sweat the three wires to the existing ir receiver terminals on the little front board. Does anyone have any advice or tips for doing this? I'm going to start by looking for a female jack with wire leads if I can find one, OR remove one from an old device that's obsolete. I will do some research and try to get this done.
I did it. Easy. I simply cut the wires off to the board and spliced them directly to a 4 foot ir extender cable, I cut the end right off it and stripped the wires, used a diagram from google images and it works perfectly. I will now order the proper female jack and redo it later using a real jack on the rear panel.
The unit works fine with that whole board unplugged, the light in the front and the ir receiver is all the functionality that it has.
Fortunately this made it real easy.
I have an aversion to bright lights also, I first used duct seal right over the led but now I realize all that has to be done is snip one of its two wires to delete the front light.
Simple stuff and fun to work on too.
Hello everyone.
I was looking for a TV box with a good wifi antenna because I can not connect the TV box with the LAN cable.
I'm undecided between this model and the Acemax m12n.
Could you tell me which of these models has the best wifi, or suggest some other model?
For example, I saw that the new model has an antenna very big, but this model is not for sale on gearbest.
Thank you very much!
Originally posted by akyelken View Postplease please give me nexbox a1 firmware link my device is boot loop is very urgent thank you
It looks like you have to register to download it...
Cheers
There are currently 2103 users online. 5 members and 2098 guests.
