I don't have but if somebody will provide it for me...
MK 802 IIIs hang
Originally posted by nimir View Postis it possible to flash backup from recovery?
This is the most tricky part and you will need a Micro USB cable (connected to computer but NOT YET connected to MK802 IIIS) and a metal stick (or pin or needle) which is thin enough to pass through the air vent on MK802 IIIS (the reset button inside the air vent located on the side next to MicroSD card slot)
Try to press and release the reset button which produce a "Click" sound. This step is just to make sure you are able to reach the right button.
if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Originally posted by nimir View PostWindows not see my device, for this reason I go to bootloader from terminal just type su -i
reboot bootloader
and in this case my computer saw device, i flashed your rom and... now I stuckif you love my work please buy a coffee
</form>
I installed it already, wehen the device is in bootloader mode it appear in Windows.
I install driver from your zip file and later install your rom.
Without it how can I install rom?
Please do in recovery backup of clear rour rom and zip directory with backup and upload it somewere,
I'll try this way
Is it possible when device is in recovery CM flash rom?
Windows see RK3066 but I can't find driver for itLast edited by nimir; 30 June 2013, 11:19.
Re: MK 802 IIIs hang
Yes just short pin the 2 dots .
Like i said in the previous posts
Verstuurd van mijn GT-S5660 met Tapatalkif you love my work please buy a coffee
</form>
Just the 2 dots left on the chip
Hold it and connect to pc.
When you hear the connection with the pc you may loose the dots
</form>
Not worry if it is a little different.
Do you have the 2 solder dots?
</form>
If you are in maskrom mode you must erase idb first.
Then tick loader.
And then click run
</form>
There are currently 1760 users online. 0 members and 1760 guests.
